.NET
Member
darpz
Message 1 of 11 (298 Views)
Entity advice
298 Views, 10 Replies
02-26-2012 09:44 AM
Hi, i'm starting to develop a .NET plugin, so i'd like to have some advice from you experts :smileywink:
I've just to draw some rectangles on a map (a 2D layer) an then set a label that show me the name and then set other "invisible" properties that describe my area.
I thought to represent this with a region and put a label on it; I'd like that these entities have a kind of relation, like move togheter etc. and finally store into this area some properties, like strings and numbers.
i have to create a custom entity with C++ or there is some other (easier) way to do this?
thanks in advance....
Bye.
Valued Contributor
FFlix
Message 2 of 11 (267 Views)
Re: Entity advice
02-27-2012 05:44 AM in reply to: darpz
hi
database services contain a GROUP dbobject, which can take the respective label as name and any entities you want associated with it can be appended (and removed), although they remain individually editable.
felix
Distinguished Contributor
VB_Autocad_guy
Message 3 of 11 (240 Views)
Re: Entity advice
02-28-2012 01:52 PM in reply to: FFlix
I don't think you have to use C++, you could use any .NET language.
Visual Basic, C++, C# and there's some others.
But if you are learning why not try Visual basic.
Have fun, the adventure has only begun
 :smileyhappy:
Valued Mentor
KerryBrown
Message 4 of 11 (235 Views)
Re: Entity advice
02-28-2012 03:09 PM in reply to: VB_Autocad_guy
VB_Autocad_guy
If the op wants custom objects c++ ARX is the option.
.NET managed does NOT create custom objects.
Regards
class keyThumper<T> : Lazy<T>;      another  Swamper
dgorsman
Message 5 of 11 (226 Views)
Re: Entity advice
02-28-2012 03:27 PM in reply to: KerryBrown
C++ *is* the only way for custom objects, but there may be some other options that are easier to implement and friendlier to other users: static or dynamic (stretchable) block with attributes, grouped entities, either with XDATA or Extension Dictionaries/XRecords both come to mind.
As I always say, code is the end product, not the start.  There needs to be a lot of prior planning, outlines, object model research, etc. prior to writing a single line of code.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Valued Mentor
KerryBrown
Message 6 of 11 (222 Views)
Re: Entity advice
02-28-2012 04:20 PM in reply to: dgorsman
:smileyhappy:
true that !
VB_Autocad_guy
Message 7 of 11 (212 Views)
Re: Entity advice
02-28-2012 08:14 PM in reply to: KerryBrown
Thanks Kerry,
Custom Objects huh? So you can do that in Arx huh?
Thanks for clarification.
Member
darpz
Message 8 of 11 (201 Views)
Re: Entity advice
02-29-2012 02:28 AM in reply to: darpz
Thanks guys, i think i will wait a white before try to create c++ custom object.
The "Group of Entities" solution seems to be a good choice!
So i will try to put a region and a label with the name in a group, i have just another question:
Where can i put the other properties of my object, i'd like to have a group with its (invisible)
data field like a C# class; I read i can use XData, correct?
There's a tutorial that explain how to use it?
Thanks again
Cheers.
dp
matus.brlit
Message 9 of 11 (193 Views)
Re: Entity advice
02-29-2012 04:50 AM in reply to: darpz
the way to create "custom objects" in .NET is the Overrule API
XData is an easy way to stick some data to entities, but it has limitations (i think there's a maximum size of the XData), it's recomended to use ExtensionDictionary, which is also quite simple
you have to create the ExtensionDicionary with DBObject.CreateExtensionDicionary() and then add some Xrecords in it
Valued Mentor
KerryBrown
Message 10 of 11 (178 Views)
Re: Entity advice
02-29-2012 04:40 PM in reply to: matus.brlit
No,  words have meanings.
You are not logged in.
Ask the Community
