Greetings,
I need to add actions immediately after a user plots.
From browsing the discussion forum I found the following code:
Autodesk.AutoCAD.PlottingServices.PlotReactorManager prm = new Autodesk.AutoCAD.PlottingServices.PlotReactorManager();
prm.EndPlot += new Autodesk.AutoCAD.PlottingServices.EndPlotEventHandler(prm_EndPlot);
from this code I can define the required actions inside prm_EndPlot. But where do I insert the above code in the class?
Kevin
