.NET
.NET
Valued Contributor
dynamicscope
Message 1 of 9 (556 Views)
Efficient way to determine whether an area intersecting another area?
556 Views, 8 Replies
04-14-2013 05:31 PM
Hi, I need to determine whether an area intersects with another area.
For example, as you can see the picture below...
The left case can be easily determined by Polyline.IntersectWith(Polyline...).
But in the right case, the two polygons intersect/overlap each other while polylines do not intersect.
What would be the effiicient way to determine the right case polygons are intersecting polygons?
If someone can help me with a simple sample code (preferably in C#), it would be very appreciated.
Thank you very much in advance.
(FYI, I am currently using ObjectARX 2007.)
Hallex
Message 2 of 9 (534 Views)
Re: Efficient way to determine whether an area intersecting another area?
04-14-2013 11:16 PM in reply to: dynamicscope
Not sure about if this will be works in 2007
tested on A2010:
        [CommandMethod("care")]
        public void checkAreasIntersect()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            bool yeah=false;
            using (Transaction tr = doc.TransactionManager.StartTransaction())
                ObjectId id1 = ObjectId.Null;
                ObjectId id2 = ObjectId.Null;
                PromptEntityOptions peo = new PromptEntityOptions("\nSelect first area >>");
                peo.SetRejectMessage("\nSelect Polyline only");
                peo.AddAllowedClass(typeof(Polyline), false);
                PromptEntityResult res;
                res = ed.GetEntity(peo);
                if (res.Status != PromptStatus.OK) return;
                id1 = res.ObjectId;
                peo.Message = "\nSelect second area >>";
                id2 = res.ObjectId;
                        Entity en1 = tr.GetObject(id1, OpenMode.ForWrite) as Entity;
                        if (en1 == null) return;
                        Entity en2 = tr.GetObject(id2, OpenMode.ForRead) as Entity;
                        DBObjectCollection exids = new DBObjectCollection();
                        en1.Explode(exids);
                        foreach (DBObject obj in exids)
                            Entity en = obj as Entity;
                            Point3dCollection pts= new Point3dCollection();
                            en.IntersectWith(en2, Intersect.OnBothOperands, pts, 0, 0);
                            if (pts.Count != 0) {  yeah=true;break;  }
                        ed.WriteMessage("\nAreas were {0} an intersection", yeah ? "has" : "doesn't have");
Valued Contributor
dynamicscope
Message 3 of 9 (520 Views)
04-15-2013 01:17 AM in reply to: Hallex
Thank you, Hallex.
I tried with the code, but it couldn't handle the right case.
So, I changed the code a little bit and tried again.
//en.IntersectWith(en2, Intersect.OnBothOperands, pts, 0, 0);
en.IntersectWith(en2, Intersect.ExtendThis, pts, 0, 0);
Well, this could handle the right case but also creates another issue.
It will consider the following case as the intersecting polygons as well.
_gile
Message 4 of 9 (517 Views)
04-15-2013 01:23 AM in reply to: dynamicscope
What about creating regions from the polylines, operate a boolean union and compare the region area with the sum of the polylines area ?
Gilles Chanteau
Valued Contributor
dynamicscope
Message 5 of 9 (506 Views)
04-15-2013 03:07 AM in reply to: _gile
That looks working. I will try it out. Thank you.
Valued Mentor
DiningPhilosopher
Message 6 of 9 (488 Views)
04-15-2013 09:44 AM in reply to: _gile
Works if the polylines aren't self-intersecting, and you probably can just check for inner-loops in that case
Valued Contributor
dynamicscope
Message 7 of 9 (445 Views)
04-17-2013 07:14 PM in reply to: _gile
Do you know if there is any method that is related to Union command? I need to compute the area of intersecting region. So I am planning to do Region1 + Region2 - UnionRegion = IntersectingArea. I need to do this programmatically (no user interaction).
_gile
Message 8 of 9 (441 Views)
04-17-2013 10:21 PM in reply to: dynamicscope
Look at the Region.BooleanOperation() method.
Gilles Chanteau
Valued Contributor
dynamicscope
Message 9 of 9 (435 Views)
04-17-2013 10:27 PM in reply to: _gile
Great~!
