.NET
Edit multiple drawings -Enotaplicable
4 REPLIES 4
552 Views, 4 Replies
Hi
I am  trying to edit multiple drawings by changing DBtext i MText objects.
tekstovi lt = new tekstovi();
            Double pov = (Double)numericUpDown1.Value;
            Double ps = (Double)numericUpDown2.Value;
            if (true)
                System.IO.StreamWriter sw = new System.IO.StreamWriter(plf+"logzamjene.txt");
                foreach (string put in filepathss)
                    try
                        doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(put.Replace("\\\\","\\"),false);
                    catch (System.Runtime.InteropServices.COMException ex)
                        System.Windows.Forms.MessageBox.Show(ex.Message);
                        throw;
                    Database db = doc.Database;
                        Editor ed = doc.Editor;
                    DocumentLock lok = doc.LockDocument();
                    using (lok)
                        using (Transaction tr = db.TransactionManager.StartTransaction())
                            try
                                SelectionFilter filter = new SelectionFilter(new TypedValue[] { new TypedValue(0, "TEXT,MTEXT") });
                                PromptSelectionResult selRes = ed.SelectAll(filter);
                                if (selRes.Status != PromptStatus.OK)
                                    MessageBox.Show("\nerror in getting the selectAll");
                                    return;
                                else
                                    foreach (SelectedObject so in selRes.Value)
                                        DBObject ob = tr.GetObject(so.ObjectId, OpenMode.ForWrite);
                                        bool neispravno = false;
                                        DBText dbt = ob as DBText;
                                        MText mt = ob as MText;
                                        if (dbt != null)
                                            String t = dbt.TextString;
                                            if (t.Contains("+"))
                                                Double bb;
                                                tekst tt;
                                                if (Double.TryParse(t.Replace(",", ".").Replace("+", ""), out bb))
                                                    if (bb > ps)
                                                        Double bbb = bb + pov;
                                                        tt = new tekst(bbb, bb, so.ObjectId, t);
                                                        lt.dodaj(tt);
                                                        dbt.TextString = bbb.ToString("0+000.00");
                                                        neispravno = false;
                                                    else
                                                        neispravno = true;
                                                else
                                                    neispravno = true;
                                                if (neispravno)
                                                    tt = new tekst(0, 0, so.ObjectId, t);
                                            else
                                                tekst tt = new tekst(0, 0, dbt.ObjectId, t);
                                        else if (mt != null)
                                            String t = mt.Contents;
                                                Double bb;
                                                tekst tt;
                                                    if (bb > ps)
                                                        lt.dodaj(tt);
                                                        mt.Contents = bbb.ToString("0+000.00");
                                                        neispravno = false;
                                                    else
                                                        neispravno = true;
                                                else
                                                    neispravno = true;
                                                if (neispravno)
                                            else
                                lt.ispisi(sw);
                                sw.Close();
                                sw.Dispose();
                            catch (System.Exception ex)
                                tr.Abort();
                                sw.Close();
                                sw.Dispose();
                            tr.Commit();
                        doc.CloseAndSave(put);
                        //db.SaveAs(db.OriginalFileName, true, db.OriginalFileVersion, db.SecurityParameters);
                sw.Close();
                sw.Dispose();
Error came on line:
4 REPLIES 4
norman.yuan
How do you run your code? I mean the CommandMethod, from which the code get run.
Basically,you need to set CommandFlags.Session in the CommandMethod attribute.
the Editor.SelectAll()/Selectxxxx() method can only be called with current drawing.
If the commandmethod has the Session flag, newly opened drawing will become current automatically. If there is no Session flag, drawing can be opened, but it would not become active drawing, thus you cannot use its Editor object and its method (SelectAll(), in your case), thus the "eNotApplicable" exception.
In following code, the Editor.SelectAll() works for me (Acad2015), with the CommandFlags.Session set:
    public class MyCadCommands
        [CommandMethod("OpenDwgs", CommandFlags.Session)]
        public static void RunOpenDwgsCommand()
            Document dwg = CadApp.DocumentManager.MdiActiveDocument;
            if (dwg == null) return;
            Editor ed = dwg.Editor;
            string[] files = new string[]
                @"C:\Temp\DrawingTest1.dwg",
                @"C:\Temp\DrawingTest2.dwg"
            BatchOpenDwgs(files);
        private static void BatchOpenDwgs(string[] files)
            foreach (var file in files)
                Document dwg = Application.DocumentManager.Open(file, false);
                PromptSelectionResult res = ed.SelectAll();
                if (res.Status==PromptStatus.OK)
                    Application.ShowAlertDialog(res.Value.Count + " found!");
Norman Yuan
Drive CAD With Code
in reply to: norman.yuan
Hi
I modified Class as you suggested with session flag but still no luck.
What am I doing wrong?
[CommandMethod("istac2", CommandFlags.Session)]
public static void istac2() // This method can have any name
        System.Windows.Forms.OpenFileDialog openFileDialog2 = new System.Windows.Forms.OpenFileDialog();
        openFileDialog2.InitialDirectory = "E:\\SkyDrive\\Izvedbeni plinovod Međimurje\\uzduznjaci\\test\\";
        openFileDialog2.Filter = "dwg files (*.dwg)|*.dwg";
        openFileDialog2.FilterIndex = 1;
        openFileDialog2.RestoreDirectory = true;
        openFileDialog2.Title = "Odaberi datoteke";
        Double ps = 100;
        Double pov = 1500;
        if (openFileDialog2.ShowDialog() == System.Windows.Forms.DialogResult.OK)
			System.IO.StreamWriter sw = new System.IO.StreamWriter("E:\\SkyDrive\\Izvedbeni plinovod Međimurje\\uzduznjaci\\test\\rezultat.txt");
            foreach (string fn in openFileDialog2.FileNames)
                tekstovi tt = changest(fn, ps, pov);
                tt.ispisi(sw);
 public static tekstovi changest(string path, Double ps, Double pov)
    try
        Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(path.Replace("\\\\", "\\"), false);
			System.Windows.Forms.MessageBox.Show("\nerror in getting the selectAll");
            lt.dodaj(new tekst(0, 0, ObjectId.Null, ""));
        else
					if (dbt != null)
							Double bb;
								if (bb > ps)
									lt.dodaj(new tekst(bbb, bb, so.ObjectId, t));
									neispravno = false;
								else
									neispravno = true;
							else
								neispravno = true;
							if (neispravno)
								lt.dodaj(new tekst(0, 0, so.ObjectId, t));
						else
							lt.dodaj( new tekst(0, 0, dbt.ObjectId, t));
					else
								Double bb;
									if (bb > ps)
										neispravno = false;
									else
										neispravno = true;
								else
									neispravno = true;
								if (neispravno)
							else
					tr.Commit();
        return new tekstovi();
        return lt;
moogalm
Hi Kresimir,
If you wan't to select either TEXT or MTEXT entities ,your filter should be something like this -
TypedValue[] TypVal = new TypedValue[4];
SelectionFilter filter= default(SelectionFilter);
TypVal.SetValue(new TypedValue(DxfCode.Operator, "<or"), 0);
TypVal.SetValue(new TypedValue(DxfCode.Start, "TEXT"), 1);
TypVal.SetValue(new TypedValue(DxfCode.Start, "MTEXT"), 2);
TypVal.SetValue(new TypedValue(DxfCode.Operator, "or>"), 3);
filter= new SelectionFilter(TypVal);
You stil find difficulties , I request you to send a sample project so I can analyze the issue.
madhu
norman.yuan
Which version of AutoCAD you are using?
Can you try some simplified code to just prove it does work or not work, for example the code I showed, or your code, from which you remove all the irrelevant code (only leave bare bone code to open a few drawings and call Editor.SelectAll() without filter?
Norman Yuan
Drive CAD With Code
”Boost
