.NET
Edit attributes within a block.
4 REPLIES 4
651 Views, 4 Replies
I'm trying to edit attributes of a block but is giving error. Smiley Sad
 private void ChangingAttibutes1(ObjectId[] objectIdList)
            for (int i = 0; i < objectIdList.Length; i++)
                ObjectId objectId = objectIdList[i];
                BlockReference blockReference = (BlockReference)objectId.GetObject(OpenMode.ForWrite);
                BlockTableRecord blockTableRecord = (BlockTableRecord)blockReference.BlockTableRecord.GetObject(OpenMode.ForWrite);
                Entity Entity = null;
                foreach (ObjectId item in blockTableRecord)
                    Entity = transaction.GetObject(item, OpenMode.ForWrite) as Entity;
                   /* if (Entity.GetType() == typeof(AttributeDefinition))
                        AttributeDefinition attributeDefinition = Entity as AttributeDefinition;
                        AttributeReference attributeReference = new AttributeReference();
                        attributeReference.SetAttributeFromBlock(attributeDefinition, blockReference.BlockTransform);
                        if (attributeReference.Tag == "CREV1")
                            attributeReference.TextString = myList[0];
                        else if (attributeReference.Tag == "TREV1")
                            attributeReference.TextString = myList[1];
                        else if (attributeReference.Tag == "DREV1")
                            attributeReference.TextString = myList[2];
                        else if (attributeReference.Tag == "VREV1")
                            attributeReference.TextString = myList[3];
                        else if (attributeReference.Tag == "AREV1")
                            attributeReference.TextString = myList[4];
                        else if (attributeReference.Tag == "DATAREV1")
                            attributeReference.TextString = myList[5];
                        else if (attributeReference.Tag == "SREV1")
                            attributeReference.TextString = myList[6];
4 REPLIES 4
                foreach (ObjectId item in blockReference.AttributeCollection)
                    if (Entity.GetType() == typeof(AttributeReference))
                        AttributeReference attributeReference = Entity as AttributeReference;
 It worked! Thank you!
Hallex
Think easier yet to use Dictionary or SortedList to update attributes, e.g. :
         [CommandMethod("attupd")]
        public static void AttributeUpdate()
            bool success = true;
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            try
                // create options object
                PromptSelectionOptions pso = new PromptSelectionOptions();
                // add messages to options object
                pso.MessageForRemoval = "\n\tSelect a block references only!";
                pso.MessageForAdding = "\n\tSelect a block references >> ";
                // create filter object for attributed block references:
                SelectionFilter filter = new SelectionFilter(new TypedValue[] { new TypedValue(0, "insert"), new TypedValue(66, 1) });
                // do selection
                PromptSelectionResult psr = ed.GetSelection(pso, filter);
                //check if selection is succeed
                if (psr.Status != PromptStatus.OK) return;
                using (DocumentLock docloc = doc.LockDocument())
                    using (Transaction tr = db.TransactionManager.StartTransaction())
                        // get an array of ObjectIds
                        ObjectId[] ids = psr.Value.GetObjectIds();
                        //tags
                        string[] tags = { "TAG1", "TAG2", "TAG3", "TAG4" };
                        //to your settings (check yourself):
                        // string[] tags = { "CREV1", "TREV1", "DREV1", "VREV1", "AREV1", "DATAREV1", ",", "SREV1" };
                        //values
                        string[] values = { "FirstValue", "SecondValue", "ThirdValue", "ForthValue" };
                        //populate a dictionary with data:
                        Dictionary<string, string> dict = FillDictionary(tags, values);
                        //execute update command
                        AttUpdFromDict(tr, ids, dict);
                        // commit transaction, will be disposed automatically because if it's inside the "Using{}" code block
                        tr.Commit();
                //  you might be want to dispaly a message here in case if the program was ended up succesfully
                //  ed.WriteMessage("Done");
            catch (System.Exception ex)
                success = false;
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message + "\n" + ex.StackTrace);
            finally
                //do nothing or display your message here
                ed.WriteMessage("\nCommand ended up with result of \"{0}\"",success==true? "Success": "Error");
        public static Dictionary<string, string> FillDictionary(string[] tags, string[] values)
            Dictionary<string, string> dict = new Dictionary<string, string>();
            if (tags.Length != values.Length)
                throw new System.Exception("Arrays have a different number of elements. Error...");
            for (int i = 0; i < tags.Length; i++)
                dict.Add(tags[i], values[i]);
            return dict;
        public static void AttUpdFromDict(Transaction tr, ObjectId[] objectIdList, Dictionary<string, string> dict)
                BlockReference blockReference = (BlockReference)tr.GetObject(objectId, OpenMode.ForWrite);
                    Entity ent = tr.GetObject(item, OpenMode.ForWrite, false) as Entity;
                    if (ent.GetType() == typeof(AttributeReference))
                        AttributeReference attRef = ent as AttributeReference;
                        if (dict.ContainsKey(attRef.Tag))
                            attRef.TextString = dict[attRef.Tag];
Thank you. I will adopt!
Hallex
You're welcome
Cheers 🙂
~'J'~
”Boost
