I'm using VS 2005 with 'Edit and Continue' enabled. I set a break point in
my code and start the DLL. It fires up AutoCAD and then stops at the break
point. When I try to edit the code it tells me :
'Cannot currently modify this text in the editor. It is read only.'
Is this feature not supported yet? It's the main reason I want to use VS
2005. Has anyone else used Edit and Continue yet?
Dale
