.NET
Dynamically defun function at load-time
3 REPLIES 3
wesbird
319 Views, 3 Replies
Hi
I am new to .net. I go over the lab which are pretty good. Thanks.
I have a question, in .Net, command is defined in the way like:
[CommandMethod("CREATE")]
public void Create()
can I generate a command on the fly?
Thank you
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
3 REPLIES 3
in reply to: wesbird
No.
What are you trying to do?
Albert
wrote in message news:4963330@discussion.autodesk.com...
Hi
Thank you
Wes
wesbird
We plan to create a addin in AutoCAD as a client, it will connect to a server (database/application) through internet. We try to keep every business related on server so the command'd better be generated on the fly.
A workaround is use parameter. Can I use parameter in AutoCAD .NET command?
I tested something on the VB6 dll first. Thank to this newsgroup, I found a solution to create command with parameter like this:
Sub MyMacro()
Dim Param1 As String, Param2 As String
Param1 = ThisDrawing.Utility.GetString(False)
Param2 = ThisDrawing.Utility.GetString(False)
MsgBox "Param1:" & Param1 & ". Param2:" & Param2
End Sub
In my menu, I just add code like:
strCmd = "(command ""-VBARUN"" ""MyMacro"" ""a"" ""b"") "
Is this doable in .NET?
Thank you
Wes
Yes, the same thing is doable in .NET.
Albert
wrote in message news:4963910@discussion.autodesk.com...
command?
Sub MyMacro()
End Sub
Thank you
Wes
”Boost
