.NET
Dynamic block screen update issue.
1 REPLY 1
333 Views, 1 Reply
"I have a dynamic block with an associated hatch. When I insert it through .Net API and then change the dynamic properties (again with .Net) the hatch doesn't get updated. I have to issue a REGEN command to update it. I didn't have this problem in VBA. Is there any method I can use to force a regen of only that block on screen. I tried blkRef.Draw() but it didn't help.
1 REPLY 1
may be it helps:
Private Sub UpdateBlockGraphic(ByVal BlockID As ObjectId)
Using db As Database = Application.DocumentManager.MdiActiveDocument.Database
Using tr As Transaction = db.TransactionManager.StartTransaction
Dim curBlock As BlockReference = CType(tr.GetObject(BlockID, OpenMode.ForWrite), BlockReference)
curBlock.RecordGraphicsModified(True)
tr.Commit()
tr.Dispose()
End Using
End Using
End Sub
or try:
Autodesk.AutoCAD.ApplicationServices.Application.UpdateScreen()
”Boost
