Hello to All,
After long time i am coming back to AutoCAD customization from Inventor and Vault.
Scenario:
I have a drawing which has multiple Dynamic Blocks with different values.
I am trying to Insert Specific Blocks and new dwg file at a specified location.
i searched in forum and found few codes but they are operated using mouse points.
These are the two codes i Referred
In either case we should decide which block to insert in which location and creare a new file
Regards
Amit
Senior Software Engineer.
Hi Amit,
Sorry for the delay.
Can you please explain the problem you are having in getting the code from those forum posts to work for you ?
If you do not need the point as an input from the user, you can choose to provide it directly as a Point3d without using the "PromptPointResult".
Balaji
