.NET
Dynamic Block Parameter Visibility
3 REPLIES 3
GeeHaa
999 Views, 3 Replies
I need to know where to look to find if a point parameter is visible the the current visibility state of the dynamic block reference.
Thanks in advance
3 REPLIES 3
Balaji_Ram
in reply to: GeeHaa
Have you tried the code from this blog post ?
http://adndevblog.typepad.com/autocad/2012/05/accessing-visible-entities-in-a-dynamic-block.html
Balaji
Developer Technical Services
Autodesk Developer Network
GeeHaa
in reply to: GeeHaa
This is what I was looking for.
GeeHaa
in reply to: Balaji_Ram
Hi I'm having trouble with the code in the suggested solution. I translated it to VB.net and I am getting an error EntryPoint "?" not found in acdb19.dll. I'm using acdb19.dll because it couldn't find acdb18.dll
Public Sub DynablockVisibilityStates()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
                        Dim per As PromptEntityResult = ed.GetEntity(vbLf + "Select Dynamic Block ")
            If per.Status <> PromptStatus.OK Then
                Return
            Using myTrans As Transaction = db.TransactionManager.StartTransaction()
                Dim ent As Entity = myTrans.GetObject(per.ObjectId, OpenMode.ForRead)
                Dim bref As BlockReference = Nothing
                If TypeOf ent Is BlockReference Then
                    bref = ent
                Dim bt As BlockTable = TryCast(myTrans.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                               Dim btr As BlockTableRecord = myTrans.GetObject(bref.DynamicBlockTableRecord, OpenMode.ForRead)
                               If Not btr.IsDynamicBlock Then
                    ed.WriteMessage(vbLf & "Not a dynamic block :(")
                    Return
                If btr.ExtensionDictionary = Nothing Then
                    ed.WriteMessage(vbLf & "No ExtensionDictionary :(")
                    Return
                Dim dict As DBDictionary = TryCast(myTrans.GetObject(btr.ExtensionDictionary, OpenMode.ForRead), DBDictionary)
                If Not dict.Contains("ACAD_ENHANCEDBLOCK") Then
                    ed.WriteMessage(vbLf & "ACAD_ENHANCEDBLOCK Entry not found :(")
                    Return
                Dim graphId As ObjectId = dict.GetAt("ACAD_ENHANCEDBLOCK")
                Dim parameterIds As System.Collections.Generic.List(Of Object) = acdbEntGetObjects(graphId, 360)
                For Each parameterId As Object In parameterIds
                    Dim id As ObjectId = DirectCast(parameterId, ObjectId)
                    If id.ObjectClass.Name = "AcDbBlockVisibilityParameter" Then
                        Dim visibilityParam As System.Collections.Generic.List(Of TypedValue) = acdbEntGetTypedVals(id)
                        Dim enumerator As System.Collections.Generic.List(Of TypedValue).Enumerator = visibilityParam.GetEnumerator()
                        While enumerator.MoveNext()
                            If enumerator.Current.TypeCode = 303 Then
                                Dim group As String = DirectCast(enumerator.Current.Value, String)
                                Dim nbEntitiesInGroup As Integer = CInt(enumerator.Current.Value)
                                ed.WriteMessage((Convert.ToString(vbLf & " . Visibility Group: ") & group) + " Nb Entities in group: " + nbEntitiesInGroup)
                                For i As Integer = 0 To nbEntitiesInGroup - 1
                                    Dim entityId As ObjectId = DirectCast(enumerator.Current.Value, ObjectId)
                                    Dim entity As Entity = TryCast(myTrans.GetObject(entityId, OpenMode.ForRead), Entity)
                                    ed.WriteMessage(vbLf & "    - " + entity.ToString() + " " + entityId.ToString())
                                Next
                        End While
                        Exit For
                Next
                myTrans.Commit()
            End Using
        End Sub
        Public Structure ads_name
            Private a As IntPtr
            Private b As IntPtr
        End Structure
        <Runtime.InteropServices.DllImport("acdb19.dll", CallingConvention:=System.Runtime.InteropServices.CallingConvention.Cdecl, EntryPoint:="?acdbGetAdsName@@YA?AW4ErrorStatus@Acad@@AAY01JVAcDbObjectId@@@Z")> _
        Public Shared Function acdbGetAdsName(ByRef name As ads_name, objId As ObjectId) As Integer
        End Function
        <Runtime.InteropServices.DllImport("acad.exe", CharSet:=System.Runtime.InteropServices.CharSet.Ansi, CallingConvention:=System.Runtime.InteropServices.CallingConvention.Cdecl, EntryPoint:="acdbEntGet")> _
        Public Shared Function acdbEntGet(ByRef ename As ads_name) As System.IntPtr
        End Function
        Private Function acdbEntGetObjects(id As ObjectId, dxfcode As Short) As System.Collections.Generic.List(Of Object)
            Dim result As New System.Collections.Generic.List(Of Object)()
            Dim name As New ads_name()
            Dim res As Integer = acdbGetAdsName(name, id)
            Dim rb As New ResultBuffer()
            Autodesk.AutoCAD.Runtime.Interop.AttachUnmanagedObject(rb, acdbEntGet(name), True)
            Dim iter As ResultBufferEnumerator = rb.GetEnumerator()
            While iter.MoveNext()
                Dim typedValue As TypedValue = CType(iter.Current, TypedValue)
                If typedValue.TypeCode = dxfcode Then
                    result.Add(typedValue.Value)
            End While
            Return result
        End Function
        Private Function acdbEntGetTypedVals(id As ObjectId) As System.Collections.Generic.List(Of TypedValue)
            Dim result As New System.Collections.Generic.List(Of TypedValue)()
                result.Add(CType(iter.Current, TypedValue))
            End While
            Return result
        End Function
    End Class
”Boost
