I need to know where to look to find if a point parameter is visible the the current visibility state of the dynamic block reference.
Thanks in advance
Solved by Balaji_Ram. Go to Solution.
Have you tried the code from this blog post ?
http://adndevblog.typepad.com/autocad/2012/05/accessing-visible-entities-in-a-dynamic-block.html
Hi I'm having trouble with the code in the suggested solution. I translated it to VB.net and I am getting an error EntryPoint "?" not found in acdb19.dll. I'm using acdb19.dll because it couldn't find acdb18.dll
Public Sub DynablockVisibilityStates() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim per As PromptEntityResult = ed.GetEntity(vbLf + "Select Dynamic Block ") If per.Status <> PromptStatus.OK Then Return End If Using myTrans As Transaction = db.TransactionManager.StartTransaction() Dim ent As Entity = myTrans.GetObject(per.ObjectId, OpenMode.ForRead) Dim bref As BlockReference = Nothing If TypeOf ent Is BlockReference Then bref = ent End If Dim bt As BlockTable = TryCast(myTrans.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable) Dim btr As BlockTableRecord = myTrans.GetObject(bref.DynamicBlockTableRecord, OpenMode.ForRead) If Not btr.IsDynamicBlock Then ed.WriteMessage(vbLf & "Not a dynamic block :(") Return End If If btr.ExtensionDictionary = Nothing Then ed.WriteMessage(vbLf & "No ExtensionDictionary :(") Return End If Dim dict As DBDictionary = TryCast(myTrans.GetObject(btr.ExtensionDictionary, OpenMode.ForRead), DBDictionary) If Not dict.Contains("ACAD_ENHANCEDBLOCK") Then ed.WriteMessage(vbLf & "ACAD_ENHANCEDBLOCK Entry not found :(") Return End If Dim graphId As ObjectId = dict.GetAt("ACAD_ENHANCEDBLOCK") Dim parameterIds As System.Collections.Generic.List(Of Object) = acdbEntGetObjects(graphId, 360) For Each parameterId As Object In parameterIds Dim id As ObjectId = DirectCast(parameterId, ObjectId) If id.ObjectClass.Name = "AcDbBlockVisibilityParameter" Then Dim visibilityParam As System.Collections.Generic.List(Of TypedValue) = acdbEntGetTypedVals(id) Dim enumerator As System.Collections.Generic.List(Of TypedValue).Enumerator = visibilityParam.GetEnumerator() While enumerator.MoveNext() If enumerator.Current.TypeCode = 303 Then Dim group As String = DirectCast(enumerator.Current.Value, String) enumerator.MoveNext() Dim nbEntitiesInGroup As Integer = CInt(enumerator.Current.Value) ed.WriteMessage((Convert.ToString(vbLf & " . Visibility Group: ") & group) + " Nb Entities in group: " + nbEntitiesInGroup) For i As Integer = 0 To nbEntitiesInGroup - 1 enumerator.MoveNext() Dim entityId As ObjectId = DirectCast(enumerator.Current.Value, ObjectId) Dim entity As Entity = TryCast(myTrans.GetObject(entityId, OpenMode.ForRead), Entity) ed.WriteMessage(vbLf & " - " + entity.ToString() + " " + entityId.ToString()) Next End If End While Exit For End If Next myTrans.Commit() End Using End Sub Public Structure ads_name Private a As IntPtr Private b As IntPtr End Structure <Runtime.InteropServices.DllImport("acdb19.dll", CallingConvention:=System.Runtime.InteropServices.CallingConvention.Cdecl, EntryPoint:="?acdbGetAdsName@@YA?AW4ErrorStatus@Acad@@AAY01JVAcDbObjectId@@@Z")> _ Public Shared Function acdbGetAdsName(ByRef name As ads_name, objId As ObjectId) As Integer End Function <Runtime.InteropServices.DllImport("acad.exe", CharSet:=System.Runtime.InteropServices.CharSet.Ansi, CallingConvention:=System.Runtime.InteropServices.CallingConvention.Cdecl, EntryPoint:="acdbEntGet")> _ Public Shared Function acdbEntGet(ByRef ename As ads_name) As System.IntPtr End Function Private Function acdbEntGetObjects(id As ObjectId, dxfcode As Short) As System.Collections.Generic.List(Of Object) Dim result As New System.Collections.Generic.List(Of Object)() Dim name As New ads_name() Dim res As Integer = acdbGetAdsName(name, id) Dim rb As New ResultBuffer() Autodesk.AutoCAD.Runtime.Interop.AttachUnmanagedObject(rb, acdbEntGet(name), True) Dim iter As ResultBufferEnumerator = rb.GetEnumerator() While iter.MoveNext() Dim typedValue As TypedValue = CType(iter.Current, TypedValue) If typedValue.TypeCode = dxfcode Then result.Add(typedValue.Value) End If End While Return result End Function Private Function acdbEntGetTypedVals(id As ObjectId) As System.Collections.Generic.List(Of TypedValue) Dim result As New System.Collections.Generic.List(Of TypedValue)() Dim name As New ads_name() Dim res As Integer = acdbGetAdsName(name, id) Dim rb As New ResultBuffer() Autodesk.AutoCAD.Runtime.Interop.AttachUnmanagedObject(rb, acdbEntGet(name), True) Dim iter As ResultBufferEnumerator = rb.GetEnumerator() While iter.MoveNext() result.Add(CType(iter.Current, TypedValue)) End While Return result End Function End Class
