.NET
BrentBurgess1980
Message 1 of 5 (296 Views)
Dynamic Block Block Tables
296 Views, 4 Replies
08-09-2012 05:21 PM
I have a dynamic block of a steel beam, with a block table, by which I can change the size etc.
public static void InsertBlock(Database db, string FileName, Point3d InsertionPoint, double Rotation = 0)
            ObjectId blkid = ObjectId.Null;
            using (Database bdb = new Database(false, true))
                bdb.ReadDwgFile(FileName, System.IO.FileShare.Read, true, "");
                blkid = db.Insert(System.IO.Path.GetFileNameWithoutExtension(FileName), bdb, true);
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                    BlockTableRecord btr = default(BlockTableRecord);
                    btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                    using (btr)
                        BlockReference bref = new BlockReference(InsertionPoint, blkid);
                        using (bref)
                            if (bref.IsDynamicBlock)
                                DynamicBlockReferencePropertyCollection dynBrefColl = bref.DynamicBlockReferencePropertyCollection;
                                foreach (DynamicBlockReferenceProperty dynBrefProps in dynBrefColl)
                                    if (dynBrefProps.PropertyName == "Name")
                                        dynBrefProps.Value = "150UB18.0";
                            Matrix3d mat = Matrix3d.Identity;
                            bref.TransformBy(mat);
                            bref.Layer = "0";
                            bref.Rotation = Rotation;
                            btr.AppendEntity(bref);
                            tr.AddNewlyCreatedDBObject(bref, true);
                    tr.Commit();
 Once the beam is placed from this code, I can change the size from the list, but there is no physical change.
If I comment out,
  the size will change when I select it. The 150UB18.0 is in the list when you call GetAllowedValues for the Name.
Does anyone know how to successfully set a value? I have looked at
GetAllowedValues().SetValue(object value, int index)  but not too sure how this one works.
Valued Mentor
gasty1001
Message 2 of 5 (289 Views)
Re: Dynamic Block Block Tables
08-09-2012 07:19 PM in reply to: BrentBurgess1980
I think you need to append the blockreference and add it to the transaction *BEFORE* to access and edit the dynamic properties, after that you need to call UpdateAnonymousBlocks() and commit the tranasaction.
Gaston Nunez
BrentBurgess1980
Message 3 of 5 (286 Views)
08-09-2012 07:30 PM in reply to: gasty1001
Gaston - You are a champ!!! that worked!!
BrentBurgess1980
Message 4 of 5 (283 Views)
08-09-2012 07:33 PM in reply to: gasty1001
Here is the snippet. I replaced the original Using with this one.
using (btr)
                        bref = new BlockReference(InsertionPoint, blockID);
                        using (bref)
                            bref.Layer = "0";
Valued Mentor
gasty1001
Message 5 of 5 (279 Views)
08-09-2012 08:03 PM in reply to: BrentBurgess1980
Hi Brent,
Glad to help you.
Gaston Nunez
You are not logged in.
Ask the Community
