.NET
Dwg thumbnail view using .Net
7 REPLIES 7
Message 1 of 8
RamanSBV
5204 Views, 7 Replies
I can get the thumbnail view of the active document from below code
Document doc = Application.DocumentManager.MdiActiveDocument;
System.Drawing.Bitmap bit = doc.Database.ThumbnailBitmap;
How can i get the thumbnail view of the dwg file by passing filename means like below.
Document doc = .....(fileName)  :  here fileName is dwg file.
Please advise on this issue.
Raman
7 REPLIES 7
Message 2 of 8
Hallex
in reply to: RamanSBV
Google is your friend:
http://www.google.ru/search?ie=UTF-8&hl=ru&q=DisplayPreviewFromDwg
Here is one from my program:
http://forums.augi.com/showpost.php?p=1085953&postcount=2
Code Conveter
http://converter.telerik.com/
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 8
http://www.theswamp.org/index.php?topic=30985.msg442803#msg442803
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 4 of 8
RamanSBV
in reply to: Hallex
This code is good.
But i am using 2010. will it works?
Please advise me
Raman
Message 5 of 8
Alfred.NESWADBA
it's just copy&paste, compile and test .... so why not trying it?
And if you look to the code you'll see it does not use any AutoCAD-lib-functions. so it's independent from any AutoCAD-version (it just reads the icon-part of the image header)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 6 of 8
RamanSBV
in reply to: Alfred.NESWADBA
I am not looking for what you have suggested means using with out autocad.
I would like to use AutoCAD API for getting thumbnail. (Message 2).
Please advise.
Thanks is advance.....
Message 7 of 8
Alfred.NESWADBA
Why do you have to use the AutoCAD API if you can get the same result without it?
if you want to calculate sin(alpha) ... what could be the reason for doing that with a specific API from AutoCAD instead of the global Math-namespace?
Sorry if I bother you, I'd like to understand why doing something more complex that can be achieved in an easy way (ready to use and independet from any AutoCAD release).
- alfred -
Alfred NESWADBA
Message 8 of 8
RamanSBV
Thanks you very much... I do as you suggested...
-Raman
”Boost
