.NET
Valued Contributor
RamanSBV
Message 1 of 8 (1,256 Views)
Dwg thumbnail view using .Net
1256 Views, 7 Replies
03-01-2012 05:51 AM
I can get the thumbnail view of the active document from below code
Document doc = Application.DocumentManager.MdiActiveDocument;
System.Drawing.Bitmap bit = doc.Database.ThumbnailBitmap;
How can i get the thumbnail view of the dwg file by passing filename means like below.
Document doc = .....(fileName)  :  here fileName is dwg file.
Please advise on this issue.
Raman
Hallex
Message 2 of 8 (1,251 Views)
Re: Dwg thumbnail view using .Net
03-01-2012 06:13 AM in reply to: RamanSBV
Google is your friend:
http://www.google.ru/search?ie=UTF-8&hl=ru&q=DisplayPreviewFromDwg
Here is one from my program:
http://forums.augi.com/showpost.php?p=1085953&postcount=2
Code Conveter
http://converter.telerik.com/
~'J'~
Moderator
Alexander.Rivilis
Message 3 of 8 (1,218 Views)
03-01-2012 12:43 PM in reply to: RamanSBV
http://www.theswamp.org/index.php?topic=30985.msg442803#msg442803
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
RamanSBV
Message 4 of 8 (1,176 Views)
03-04-2012 10:25 PM in reply to: Hallex
This code is good.
But i am using 2010. will it works?
Please advise me
Raman
Alfred.NESWADBA
Message 5 of 8 (1,169 Views)
03-04-2012 11:01 PM in reply to: RamanSBV
it's just copy&paste, compile and test .... so why not trying it?
And if you look to the code you'll see it does not use any AutoCAD-lib-functions. so it's independent from any AutoCAD-version (it just reads the icon-part of the image header)
- alfred -
Alfred NESWADBA
Valued Contributor
RamanSBV
Message 6 of 8 (1,166 Views)
03-04-2012 11:47 PM in reply to: Alfred.NESWADBA
I am not looking for what you have suggested means using with out autocad.
I would like to use AutoCAD API for getting thumbnail. (Message 2).
Please advise.
Thanks is advance.....
Alfred.NESWADBA
Message 7 of 8 (1,145 Views)
03-05-2012 09:34 AM in reply to: RamanSBV
Why do you have to use the AutoCAD API if you can get the same result without it?
if you want to calculate sin(alpha) ... what could be the reason for doing that with a specific API from AutoCAD instead of the global Math-namespace?
Sorry if I bother you, I'd like to understand why doing something more complex that can be achieved in an easy way (ready to use and independet from any AutoCAD release).
- alfred -
Alfred NESWADBA
Valued Contributor
RamanSBV
Message 8 of 8 (1,128 Views)
03-05-2012 08:24 PM in reply to: RamanSBV
Thanks you very much... I do as you suggested...
-Raman
You are not logged in.
Ask the Community
