• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    jamkhp
    Drawing Saveas is not given expected results
    292 Views, 8 Replies
    06-01-2011 07:54 AM
    Hi all,
    Here is a code snippet which is helping me save the file in acad 2000 format, it is working fine, I am facing one minor problem with this, the arrowheads of the dimension are not visible, but the dimensionstyle shows that the arrow head exists, and the whole dimension is one entity( I mean it is not exploded). any suggestions so that I can improve on this, I want the dwg to be saved in 2000 format only, whilst I am constructing it in 2011 through VB.Net.
    ' ' Start Code
    Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
    Dim strDWGName As String = saveFileDia.FileName   ' Name and path extracted from SavefileDialog box
    acDoc.Database.SaveAs(strDWGName, True, DwgVersion.AC1015, acDoc.Database.SecurityParameters)
    ' ' Ending of the Code
    this is what I see in the drawing
    ** I tried changing the background color just to see that arrow has changed its color, but it is not the case
    But on the same file if I do a dxfout(), then it is coming good I dont see this condition.
    Please help me.
    Please use plain text.
    arcticad
    Re: Drawing Saveas is not given expected results
    06-01-2011 08:01 AM in reply to: jamkhp
    Your problem is not the file format. but that annotative dimentioning isn't supported in 2000.
    “We don’t have a snowball’s chance in a blast furnace of surviving this attack unless every one of our units gets into the fight right now!”
    jamkhp
    06-01-2011 08:16 AM in reply to: arcticad
    Hey that was quick,
    is this what I need to add
    acAliDim.Annotative= AnnotativeStates.False
    or
    acAliDim.Annotative= AnnotativeStates.Notapplicable
    Sorry I cant run autocad out of my Company so I am asking this question since you are available, please bear with, in fact I should have trid myself.
    Thanks for the quickest help I have ever got.
    jamkhp
    06-01-2011 09:10 AM in reply to: jamkhp
    Hi some how I got acces to autocad,
    Sorry to say this I am not able to do it, I tried by the methods that I had hit me,
    it is not working,
    please help me.
    arcticad
    06-01-2011 09:40 AM in reply to: jamkhp
    Post your Autocad file, the original and the saved as
    jamkhp
    06-01-2011 10:08 AM in reply to: arcticad
    jamkhp
    06-04-2011 03:37 AM in reply to: jamkhp
    Hi I have posted my files,
    any success with that?
    jamkhp
    06-04-2011 03:38 AM in reply to: arcticad
    hi please reply...
    arcticad
    06-06-2011 06:49 AM in reply to: jamkhp
    The error you are seeing is not because of anything code related.
    It has to do with the drawing failing validation.
    This is a known problem. I've seen it since 2008
    When a drawing is opened in AutoCAD it checks to see if the file was
    last saved with an autodesk product.
    The data required for this was not supported in 2000/2004.
    The file should open just fine if you were using AutoCAD 2004.
    However when you use a newer version then it will require the file to be recovered.
    If you notice you can resave the file as a 2010 from the 2000 file in code and there are no issues with the file.
    The only fix is to resave the file into the current version.
