I am using the Plot Settings Validator object and setting them on an existing layout. After setting the plot configuration name, I get the right sheet size, but the drawing orientation is defaulting to portrait. Is there a way to orientate the paper to landscape?
hi,
have you tried set the PlotSettgins.PlotRotation property?
Augusto Goncalves
Autodesk Developer Network
Yes, it seems to have no effect. I thought plot rotation was how the drawing was rotated on the paper. Paper orientation is something different then, no?
I need to set the paper to Landscape and not Portrait.
OK, scratch that. I assumed Degrees000 was landscape. Degrees090 works.
Thanks!
