.NET
Draw with ObjectARX and C#
5 REPLIES 5
chikito1990
3751 Views, 5 Replies
Hi al,
I have a task to draw a picture(attached in the post) using ObjectARX but the picture is complicated(too many things to take into considerations) and I have no idea how accomplish the task. I will really appreciate if you give me some guidelines so I can see what is the best option. I have to use ObjectARX SDK and C# to do it.
Thank you in advance!
Best regards,
Dimitar Georgiev
5 REPLIES 5
Hallex
in reply to: chikito1990
Here you go:
http://www.codeproject.com/Articles/10724/Samples-for-DOTNETARX-a-tool-for-AutoCAD-NET-progr
me think it's enough do make your homework
Cheers 🙂
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
chikito1990
in reply to: Hallex
HI Hallex,
All is really cool but I have some trouble inserting the elements on the picture. I attached a picture with exeption i am getting and i have no idea why i do get it?
Hallex
Post this code block as .txt file,
or just paste directly in this topic,
coz could not test it from your picture,
chikito1990
in reply to: Hallex
I just trying to make the cylinder in the middle:
[CommandMethod("PM_Cable")]
        public void CableExporting()
            Point3d ellipseMajorAxis = new Point3d(0.0, 1500.0, 0.0);
            Double ellipseRadiusRatio = 0.4;
            Point3d ellipseLeftCenter = new Point3d(72541.7, 80198.5, 0.0);
            Point3d ellipseRightCenter = new Point3d(77145.7, 80173.6, 0.0);
            Point3d ellipseTopStart = new Point3d(77154.7, 81673.6, 0.0);
            Point3d ellipseTopEnd = new Point3d(72541.7, 81698.5, 0.0);
            Point3d ellipseBottumStart = new Point3d(77154.7, 78673.6, 0.0);
            Point3d ellipseBottumEnd = new Point3d(72578.5, 78701.8, 0.0);
            Ellipses ellipseLeft = new Ellipses(ellipseLeftCenter, ellipseMajorAxis, ellipseRadiusRatio);
            Ellipses ellipseRight = new Ellipses(ellipseRightCenter, ellipseMajorAxis, ellipseRadiusRatio);
            Lines ellipseTop = new Lines(ellipseTopStart, ellipseTopEnd);
            Lines ellipseButtom = new Lines(ellipseBottumStart, ellipseBottumEnd);
            Tools.AddEntities(new Entity[] { ellipseLeft, ellipseRight, ellipseTop, ellipseButtom });
 Thank you for spending your time with my question
Tags (3)
chikito1990
in reply to: Hallex
Also i am getting this warnings. But as you see from the other picture the .DLL is there.
”Boost
