Hi
I am trying to build a code without using CUI editing
when I doubleclick a block called Block_text to display a custom form
but also I do not want to take out the double click behaviour from autocad when I click on another objects
Can you point me to the right path?
I do not want to run "mst" command when I want to display the form
So far I gathered the following code:
' System
Imports System
Imports System.Collections.Generic
Imports System.Linq
Imports System.Text
Imports System.Linq.Expressions
' AutoCAD
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports acApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.EditorInput
' AutoCAD Interop
Imports acOp = Autodesk.AutoCAD.Interop
Imports acOpCom = Autodesk.AutoCAD.Interop.Common
Namespace Test1
PublicClassCommands
Public db AsDatabase = HostApplicationServices.WorkingDatabase
Public ActiveDoc_vb_net AsDocument = acApp.DocumentManager.MdiActiveDocument
Public ed AsEditor = ActiveDoc_vb_net.Editor
Private acDoc As acOp.AcadDocument
Private handlerAdded AsBoolean = False
Private Forma1 AsNewdouble_click_form' I created a form, and I added a Textbox1 to it
PublicFunction ThisDrawing()
ReturnacApp.DocumentManager.MdiActiveDocument.AcadDocument
EndFunction
PublicSub eventDoubleClick()
Try
If handlerAdded = FalseThen
acApp.SetSystemVariable("DBLCLKEDIT", 0)
acDoc = CType(ThisDrawing(), Autodesk.AutoCAD.Interop.AcadDocument)
AddHandler acDoc.BeginDoubleClick, AddressOf callback_DoubleClick
handlerAdded = True
Else
EndIf
Catch ex As Autodesk.AutoCAD.Runtime.Exception
MsgBox(ex.Message, MsgBoxStyle.Critical)
Finally
acApp.SetSystemVariable("DBLCLKEDIT", 1)
EndTry
EndSub
PrivateSub callback_DoubleClick(ByVal pickPoint AsObject)
Dim PromptSelectionResult1 AsPromptSelectionResult = ActiveDoc_vb_net.Editor.GetSelection()
Dim msg AsString = ""
Using docLock AsDocumentLock = ActiveDoc_vb_net.LockDocument()
If PromptSelectionResult1.Status <> PromptStatus.OK Then
EndIf
If PromptSelectionResult1.Value.Count <> 1 Then
EndIf
Dim id As Autodesk.AutoCAD.DatabaseServices.ObjectId = PromptSelectionResult1.Value(0).ObjectId
Try
Using acTrans As Autodesk.AutoCAD.DatabaseServices.Transaction = _
ActiveDoc_vb_net.TransactionManager.StartTransaction()
Dim dbObj As Autodesk.AutoCAD.DatabaseServices.DBObject = _
acTrans.GetObject(id, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
Dim ent As Autodesk.AutoCAD.DatabaseServices.Entity = _
TryCast(dbObj, Autodesk.AutoCAD.DatabaseServices.Entity)
Forma1.Text = ent.GetType().ToString()
If ent IsNothingThen
Exit Sub
Else
Dim blockRef As Autodesk.AutoCAD.DatabaseServices.BlockReference = _
TryCast(ent, Autodesk.AutoCAD.DatabaseServices.BlockReference)
If blockRef IsNothingThen
RemoveHandler acDoc.BeginDoubleClick, AddressOf callback_DoubleClick
Exit Sub
Else
ActiveDoc_vb_net.Editor.WriteMessage(blockRef.BlockName)
acApp.ShowModalDialog(Forma1)
EndIf
EndIf
acTrans.Commit()
EndUsing
Dim msgStr AsString = String.Format("EX: '{0}'", ex.ToString)
Catch
Dim msgStr AsString = String.Format("ERR: '{0}", Err.Description)
EndTry
EndUsing
EndSub
<CommandMethod("mst")> _
PublicSub massStraight()
Try
' Call this to override the default block dblclk event handler
eventDoubleClick()
EndTry
EndSub
EndClass
EndNamespace
If you are not using Acad2009 or earlier, you do not have to use AcadDocument.BeginDoubleClick event from COM API, you can use Application.BeginDoubleClick in ,NET API, in conjunction with other more controls mechnism provided by .NET API.
There was a lengthy discussion in this forum and that inspired me wrinte 2 articles on this topic:
http://drive-cad-with-code.blogspot.ca/2012/12/custom-double-click-action-using.html
http://drive-cad-with-code.blogspot.ca/2013/03/update-custom-double-click-action-using.html
It might be a bit helpful.
