.NET
DocumentManager.open() not open the file completely
5 REPLIES 5
osayed3202
1111 Views, 5 Replies
Hi guys,
I am trying to open document according to the paths in the listview, the open() function when it opens the file the file doesnot open completely so it ignore the subsequent commands like ((acdMgr.MdiActiveDocument.SendStringToExecute("-purge all * n", false, false, true);)) , here is the code
            DocumentCollection acdMgr = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
            string strFullPath;
            //string strTextFileName = SaveDialog.FileName;
            foreach (ListViewItem itemRow in this.lstView.Items)
                Transaction tm = acdMgr.MdiActiveDocument.Database.TransactionManager.StartTransaction();
                using (tm)
                    ListViewItem item = lstView.Items[itemRow.Index];
                    string lines = item.SubItems[0].Text;
                    string col = item.SubItems[1].Text;
                    strFullPath = col + "\\" + lines;
                    //acdMgr.Open(strFullPath, false);
                    acdMgr.Open(strFullPath,false);
                    acdMgr.MdiActiveDocument.CloseAndSave(strFullPath);
                    tm.Commit();
                //tm.Commit();
 The image attached is for the cad screen after executing the open() function.
Best Regards
O.Sayed
CAD developer
5 REPLIES 5
FRFR1426
in reply to: osayed3202
It is not the open command which not open the drawing completely it is because the SendStringToExecute which is executed at the end of your command. You have to use SendCommand instead (assuming you have the CommandFlags.Session enabled).
You can also purge without sending a command.
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
osayed3202
thanks guys for your time and support
the sendcommand() works but i am struggling using it.
 private void btnPurge_Click(object sender, EventArgs e)
            string strFullPath;
                using (tm)
                    //Thread.Sleep(3000);
                    AcadApplication app = (AcadApplication) Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
                    app.ActiveDocument.SendCommand("(command " + (char)34 +
                                                    "-Purge" + (char)34 +
                                                    " " + (char)34 +
                                                    "all" + (char)34 +
                                                    " " + (char)34 +
                                                    "*" + (char)34 +
                                                    " " + (char)34 +
                                                    "n" + (char)34 +
                                                    " " + (char)34 +
                    // this is the output in the autocad command line : (command "-Purge" "all" "*" "n" ")
                    app.ActiveDocument.SendCommand("regen ");
                    //(command "-Purge" "all" "*" "n" ")
                    //acdMgr.MdiActiveDocument.SendStringToExecute("-purge all * n", false, false, true);
                    //acdMgr.MdiActiveDocument.CloseAndDiscard();
                    tm.Commit();
                //tm.Commit();
 the output in the autocad command line like this   (command "-Purge" "all" "*" "n" ") but did not work and stick in the command line and did not execute.
Best Regards
O.Sayed
CAD developer
If you use SendCommand or SendStringToExecute then you have to add " " or "\n" to command string, e.g. "_-purge _all * _n\n"
Facebook | Twitter | LinkedIn
Expert Elite Member
Thank you all guys,
really appreciate your time and support.
bye till another discussion 🙂
Best Regards
O.Sayed
CAD developer
MrShepherd
To get it to work in vb I used this:
.SendStringToExecute("_-purge _all " & vbCr & "n ", True, False, True)
”Boost
