.NET
Document Object by a drawing file name
3 REPLIES 3
NKCAUTOCAD01
682 Views, 3 Replies
In AutoCAD.NET API, please tell me.
From DocumentManager, I want to acquire Document Object by a drawing file name.
Please tell me the method.
I would like it in VB.NET if possible.
Thanking you in advance.
3 REPLIES 3
Hallex
in reply to: NKCAUTOCAD01
Think you need all documents what is already opened
then you can try this code
       <CommandMethod("tfl")> _
        Public Sub testDrawings()
            Dim dm As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
            Dim doc As Document = dm.GetDocument(HostApplicationServices.WorkingDatabase)
            Dim ed As Editor = doc.Editor
            ed.WriteMessage(vbLf + "Current Document: {0}", doc.Name)
            Dim ienum As IEnumerator = dm.GetEnumerator
            While ienum.MoveNext
                Dim idoc As Document = DirectCast(ienum.Current, Document)
                ed.WriteMessage(vbLf + " Document item in collection: {0}", idoc.Name)
            End While
        End Sub
NKCAUTOCAD01
Dear Mr. Hallex
Thank you for immediate advice.
It was saved very much.Yours sincerely,
NKCAUTOCAD01 (M.Tsukamoto).
Hallex
You're welcome, M.Tsukamoto
Keep coding,
Cheers Smiley Happy
”Boost
