Document.CloseAndSave: Attempted to read or write protected memory
Hello Forum,
I have code that throws the following error:
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
At Autodesk.AutoCAD.ApplicationServices.Document.CloseInternal()
At Autodesk.AutoCAD.ApplicationServices.Document.CloseAndSave()
It only happens with some drawings.
Why would "Document.CloseAndSave()" throw this error? How can I prevent this/check if the document is ok to be closed and saved?
using (Document docTarget = CADS.Application.DocumentManager.Open(strTargetDwgPath, false))
try
if (!docTarget.IsReadOnly)
using (DocumentLock dlTarget = docTarget.LockDocument())
using (Transaction transTarget = docTarget.Database.TransactionManager.StartTransaction())
btTarget = transTarget.GetObject(docTarget.Database.BlockTableId, OpenMode.ForRead) as BlockTable;
foreach (string strDwgPath in strSourceDwgPathList)
++intIndex;
if (btTarget.Has(System.IO.Path.GetFileNameWithoutExtension(strDwgPath)))
using (Database dbInsert = new Database(false, true))
dbInsert.ReadDwgFile(strDwgPath, System.IO.FileShare.Read, true, "");
oidInsert = docTarget.Database.Insert(System.IO.Path.GetFileNameWithoutExtension(strDwgPath), dbInsert, true);
btrInsert = transTarget.GetObject(oidInsert, OpenMode.ForWrite) as BlockTableRecord;
if (btrInsert.IsDynamicBlock)
btrInsert.UpdateAnonymousBlocks();
++intFound;
else
++intNotFound;
btTarget = null;
transTarget.Commit();
// Save changes.
docTarget.CloseAndSave(strTargetDwgPath); // <<<< ERROR.
enuResult = DialogResult.OK;
else
docTarget.CloseAndDiscard();
mstrMessage = "Failed: file is readonly or in use.";
enuResult = DialogResult.Cancel;
catch (System.Exception Ex)
MessageBox.Show(Ex.ToString(), "A");
mstrMessage = "Error redefining blocks in multiple drawings: " + Ex.Message + " (" + System.Reflection.MethodBase.GetCurrentMethod().DeclaringType.Name + "." + System.Reflection.MethodBase.GetCurrentMethod().Name + ").";
if (docTarget != null) { docTarget.CloseAndDiscard(); }
