.NET
Do I need Autocad 2006 for development with DotNet 2006 dlls?
7 REPLIES 7
Message 1 of 8
424 Views, 7 Replies
I have autocad 2005 installed on my machine and I downloaded 2006 dll sdk and tried to use it in a C# project. The project built fine but on running, it failed to load the assembly. I also tried HelloWorld lab but the result was the same.
I tried to put the 2006 dlls in GAC but it did not succeed because dlls are not strong named. And putting it in the application base path didn't work either.
So, my question is, do I need to have autocad 2006 installed on my machine to do any development with these dlls?
TIA
kr.
7 REPLIES 7
Message 2 of 8
What version of AutoCAD did you try to load your assembly onto?
Message 3 of 8
No
AutoCAd 2005 has a .NET API as well all though it is not as complete as the
.NET API in Acad 2006.
wrote in message news:5018115@discussion.autodesk.com...
was the same.
either.
TIA
kr.
Message 4 of 8
I have autocad 2005.
Message 5 of 8
I have 2005 .Net API and I am using it in my first project (Visual Studio 2003). However, as you mentioned, it is not as comprehensive as .Net 2006 API. For this reason I wanted to try the latest one.
So, my question remains; do I need autocad 2006 on my machine to run applications developed using 2006 .Net API?
Thanks for yor reply.
kr
Message 6 of 8
I don’t think the .dll files are backward compatible (or even forward compatible?), you will need 2006 to run applications built for 2006
Message 7 of 8
Yes, you need Acad2006 for the app being built on Acad2006.NET API.
The general rule from AutoDesk on this kind of version issue is app built on
earlier version would run on later version, not the other way around.
wrote in message news:5018267@discussion.autodesk.com...
kr
Message 8 of 8
Thank you all.
kr
”Boost
