.NET
Distinquish SaveAs and Save
3 REPLIES 3
273 Views, 3 Replies
I'm trying to distinguish the difference between a Save and a SaveAs.
The only events exposed in AutoCAD are BeginSave and SaveComplete. The event args of each provide the new filename.
I want to call a function ONLY if the path or filename is changed during the save.
The only way I can think of is create a global variable when a drawing is activated and store the name of the current drawing. Then when a save is done compare the new name (e.Filename) to the old one.
is there a more elegant way I'm just not finding. (BTW I hate global variables.)
3 REPLIES 3
One way would be to look at the current command
(the CommandInProgress property of the Document
object)
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5186808@discussion.autodesk.com...
Perfect
Just one line of code:
if( Application.DocumentManager.MdiActiveDocument.CommandInProgress == "SAVEAS" )
PerformFunction( e.FileName );
Thanks so much for pointing me in the right direction. Much better than a global variable.
Remember that the AutoCAD SAVE command (invoked from
the command line) saves the file to another filename, but
does change the current document to that filename.
wrote in message news:5187702@discussion.autodesk.com...
Perfect
”Boost
