.NET
Display Windows User-Forms in AutoCAD using Vb.net
7 REPLIES 7
Message 1 of 8
fxcastil
6492 Views, 7 Replies
What is the best/prefered method for displaying Windows User-Forms in Autocad?
Below is what I have used I don;t know what the difference/advantages are?
'make a sure a reference to System.Windows.Forms exists in the project
Dim myform As System.Windows.Forms.Form
myform =
NewformTextSeries
1) Use the commands/methods from Windows (System.Windows.Forms)
' Show the User-Form
myform.SetDesktopLocation(10, 10)
myform.ShowDialog()
2) Use the commands/methods from Windows (Autocad.ApplicationServices)
' Show the User-Form  Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(myform)
Does anybody have an example of showing modeless forms using AutoCad Palettes?
7 REPLIES 7
Message 2 of 8
fieldguy
in reply to: fxcastil
Message 3 of 8
fxcastil
in reply to: fieldguy
Thanks for the tutorial, is there a "library" of Autodesk VB.Net available ?
Message 4 of 8
arcticad
http://www.vbcad.com/
This is the only book I've seen.
Are there any more?
(defun botsbuildbots() (botsbuildbots))
Message 5 of 8
Hallex
See this very basic sample code,
 this will allow you to insert block from combobox
Link removed, see private message
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 6 of 8
fxcastil
in reply to: Hallex
Thanks for the information, but I only have VB.net and can't open the "C.net" file to view it
 If you can post the code I'll be able to see the example and apply it to VB.net
Message 7 of 8
Hallex
wait till tomorrow, I can't do it right now
~'J'~
Message 8 of 8
Hallex
See attached in PM
~'J'~
”Boost
