.NET
Valued Contributor
mindofcat
Message 11 of 20 (467 Views)
Re: Display VB.Net form when block reference is double-clicked
11-14-2012 12:37 PM in reply to: Hallex
That's OK... I am truly appreciative of the time you have put into this. So the thing is, my form is modal. I would netload, then type in the command to run my form, which generates a block. Then I would type in the command to run the doubleclick event you so kindly provided.
At this point, I would expect to double-click on the block I just created, and have the default doubleclick event overridden, but no, that still doesn't happen.
What I'm trying to understand is this: When exactly is the default doubleclick event for block reference supposed to be overridden? 'Cos like I mentioned in my last post, the logic of the code you provided seems flawless, but I simply can't understand why I stil don't have the desired effect...
I trash around online quite a bit searching for more solutions, and many a time I keep getting the referral to do something with the CAD cuix file. Do you think this is feasible? And if so, can this be done from code, as opposed to typing cuix in the command line and pulling up the AutoCAD cui customization interface?
Valued Contributor
mindofcat
Message 12 of 20 (455 Views)
11-14-2012 07:35 PM in reply to: mindofcat
Here is the module I am using to accomplish doubleclick event handling:
' System
Imports Microsoft.Win32
Imports System.Reflection
' AutoCAD
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports acApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
' AutoCAD Interop
Imports acOp = Autodesk.AutoCAD.Interop
Imports acOpCom = Autodesk.AutoCAD.Interop.Common
Module ModDoubleClick
Private acDoc As acOp.AcadDocument
Private handlerAdded As Boolean = False
Public Sub eventDoubleClick()
Try
If handlerAdded = False Then
acApp.SetSystemVariable("DBLCLKEDIT", 0)
If acDoc Is Nothing Then
acDoc = CType(acApp.DocumentManager.MdiActiveDocument.AcadDocument, _
Autodesk.AutoCAD.Interop.AcadDocument)
AddHandler acDoc.BeginDoubleClick, AddressOf callback_DoubleClick
End If
handlerAdded = True
End If
Catch ex As Autodesk.AutoCAD.Runtime.Exception
MsgBox(ex.Message, MsgBoxStyle.Critical)
Finally
acApp.SetSystemVariable("DBLCLKEDIT", 1)
End Try
End Sub
Private Sub callback_DoubleClick(ByVal PickPoint As Object)
Dim activeDoc As Document = acApp.DocumentManager.MdiActiveDocument
Dim prmtSel As PromptSelectionResult = activeDoc.Editor.GetSelection()
Using docLock As DocumentLock = activeDoc.LockDocument()
If prmtSel.Status <> PromptStatus.OK Then Return
If prmtSel.Value.Count <> 1 Then Return
Dim id As Autodesk.AutoCAD.DatabaseServices.ObjectId = _
prmtSel.Value(0).ObjectId
Using acTrans As Autodesk.AutoCAD.DatabaseServices.Transaction = _
activeDoc.TransactionManager.StartTransaction()
Dim dbObj As Autodesk.AutoCAD.DatabaseServices.DBObject = _
acTrans.GetObject(id, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
Dim ent As Autodesk.AutoCAD.DatabaseServices.Entity = _
TryCast(dbObj, Autodesk.AutoCAD.DatabaseServices.Entity)
If ent Is Nothing Then
Return
Else
Dim blockRef As Autodesk.AutoCAD.DatabaseServices.BlockReference = _
TryCast(ent, Autodesk.AutoCAD.DatabaseServices.BlockReference)
If blockRef Is Nothing Then
Return
Else
activeDoc.Editor.WriteMessage(blockRef.Name)
End If
End If
acTrans.Commit()
End Using
End Using
End Sub
End Module
And the Commands class, from which my vb.net form is generated, as well as where the ModDoubleClick.eventDoubleClick() method is called:
Public Class Commands
' Component for displaying the Mass Straight Conveyor form
<CommandMethod("mst")> _
Public Shared Sub massStraight()
Try
' Call this to override default block dblclk event handler
' Display the mass straight form
Dim cForm As New frmMassStraight
acApp.ShowModalDialog(cForm)
End Try
End Sub
End Class
To execute, I start AutoCAD 2010, and type 'mst' into the command bar to run the command which both launches my form and as well 'supposedly' applies doubleclick handler.
After form execution has drawn a block, I doubleclick on the block and the AutoCAD block Attributes Editor still appears.
Really frustrating, isn't it? No end in sight, still hoping for some insight as to why the module isn't doing what it's supposed to do, override the default AutoCAD doubleclick event for blocks (with attributes)...
ADN Support Specialist
Balaji_Ram
Message 13 of 20 (425 Views)
11-21-2012 09:21 AM in reply to: mindofcat
I have attached two screenshots showing the double click actions responsible for block and attribute editing.
You may try editing the macro for the attribute edit double click action to include your command that displays the form.
I havent tried the sample code yet. Please let me know if modifying the double click action in cuix does not help. I will debug through the code that you already provided.
Balaji
Developer Technical Services
Autodesk Developer Network
Valued Contributor
mindofcat
Message 14 of 20 (410 Views)
11-21-2012 09:58 AM in reply to: Balaji_Ram
Thank you very much, let me check out your screenshots and see how it helps...
Quick word though, I would be slightly skeptical about making adjustments directly in the cuix, since this would affect ALL DOUBLE-CLICKED BLOCK REFERENCES, right?
But I am only interested in affecting double-clicked block references which were created by my form (the block name has certain identifiable substrings), while therest of the block references in the drawing would continue to exhibit the default AutoCAD double-click behavior...
Still, let me take a look at your screenshots and investigate my cuix.
Thanks for your help, much appreciated!
Further suggestions/pointers/advice still welcome.
Valued Contributor
mindofcat
Message 15 of 20 (407 Views)
11-21-2012 10:01 AM in reply to: Balaji_Ram
Any idea how to write the macro string for opening a vb.net form in the cuix double-click macro field?
In regular vb.net code, this would be acApp.ShowModalDialog(cForm), but in macro?
Hallex
Message 16 of 20 (394 Views)
11-21-2012 11:40 AM in reply to: mindofcat
Perhaps, something like
^C^C_netload "C:/Tem/myAutoCADForm.dll" ;
Valued Contributor
mindofcat
Message 17 of 20 (391 Views)
11-21-2012 12:24 PM in reply to: mindofcat
Thanks...
I checked out the cuix screenshots; unfortunately, I need to be able to accomplish this double-click action programmatically, as I feel that's the only way I shall be able to apply my custom double-click action to only specific block references, instead of ALL block references.
All the research I have done online enabled me to compile the module I posted here, and the code's logic seems sensible, but unfortunately, after I run the command, double-clicking blocks still pulls up the default autocad double-click action (attredit)
DO you have any idea how this can be made to work?
Many thanks in advance...
Cat
Virupaksha.aithal
Message 18 of 20 (376 Views)
11-22-2012 03:44 AM in reply to: mindofcat
 You can try using IMessageFilter to avoid double click message going to AutoCAD. Refer DevBlog http://adndevblog.typepad.com/autocad/2012/05/how-to-combine-a-net-jig-and-messagefilter-to-catch-us... which shows the use of IMessageFilter and blocking of right click reaching AutoCAD
Virupaksha Aithal KM
Valued Contributor
mindofcat
Message 19 of 20 (361 Views)
11-22-2012 07:26 PM in reply to: Virupaksha.aithal
Thanks for the posted link... I'm still trying to figure out how to customize that JigMsgFilter class to suit my needs. I am still relatively new to AutoCAD VB.Net customization, and so many things out there are still confusing for me, but I am finding my way thru gradually.
I am currently attempting to fingure out how the class in your post can be customized for doubleclick action...
Virupaksha.aithal
Message 20 of 20 (312 Views)
12-07-2012 02:38 AM in reply to: mindofcat
Hi ,
also take look at the new post on similar issue http://forums.autodesk.com/t5/NET/How-to-capture-double-click-event-in-AutoCAD-using-VB-NET/td-p/371...
You are not logged in.
Ask the Community
