.NET
Valued Contributor
rtejada
Message 1 of 4 (68 Views)
Dim WithEvents Exception throw
68 Views, 3 Replies
09-18-2006 07:51 PM
To get all the application and document event handlers in visual studio 2005 I create the following variables at a class level
Dim WithEvents AcadApp As AcadApplication = CType(Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication, AcadApplication)
Dim WithEvents AcadDoc As AcadDocument = CType(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument, AcadDocument)
When I execute the code, It goes fine trought the AcadApps declaration but then it throws a exception at the AcadDoc declaration.
Is there any diference between both objects?
Please advice
*Tony Tanzillo
Message 2 of 4 (68 Views)
Re: Dim WithEvents Exception throw
09-19-2006 01:02 AM in reply to: rtejada
You're confusing COM/ActiveX types with managed types.
There is no AcadApplication or AcadDocument in the
managed API, those are COM objects, not managed types,
so you can't use the MdiActiveDocument property (whose
value is the managed 'Document' type).
You need to use:
AcadApp.ActiveDocument, AcadDocument)
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5333442@discussion.autodesk.com...
Please advice
Valued Contributor
rtejada
Message 3 of 4 (68 Views)
09-19-2006 06:46 AM in reply to: rtejada
Thank you Tony, I am out of the office, I will try your suggestion ASAP
Valued Contributor
rtejada
Message 4 of 4 (68 Views)
09-19-2006 11:10 AM in reply to: rtejada
Thanks again Tony, I was able to test it and it works. It seems that visual 2003 was not sensitive about it, so I just realize it with the visual studio 2005.
Regards
Raul
You are not logged in.
Announcements
Need installation help?
Ask the Community
