.NET
Valued Contributor
hoathuongphuoc
Message 1 of 9 (467 Views)
Determine Top of polyline follow direction x-axits and original
467 Views, 8 Replies
12-26-2013 10:59 PM
Hi All,
As above Subject. How can i determine "StartPoint" top of polyline. i have attach image:
When i change UCS:
Thanks everybody.
SENL1362
Message 2 of 9 (442 Views)
Re: Determine Top of polyline follow direction x-axits and original
12-27-2013 12:00 AM in reply to: hoathuongphuoc
1. For Hinh1 (the UCS oriented like the WCS(ZAngle1=ZAngle2)):
Sort WCS coordinates based on X, then on Y
pts.OrderBy(p => p.X).ThenBy(p => p.Y).First();
2. For the other one:
Sort WCS coordinates large to small based on Y, then on X
pts.OrderByDescending(p => p.Y).ThenByDecending(p => p.X).First();
Valued Contributor
hoathuongphuoc
Message 3 of 9 (423 Views)
12-27-2013 01:06 AM in reply to: SENL1362
Sorry SENL1362, But i dont understant whats your meaning. Can you give me a example.
Valued Contributor
hoathuongphuoc
Message 4 of 9 (404 Views)
12-27-2013 02:09 AM in reply to: hoathuongphuoc
When i changed ucs so point tops of this polyline dont change.
_gile
Message 5 of 9 (392 Views)
12-27-2013 02:48 AM in reply to: hoathuongphuoc
may be you can get some inspiration from this:
    public class Commands
        [CommandMethod("Test")]
        public void Test()
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptEntityOptions opts = new PromptEntityOptions("\nSelect a polyline: ");
            opts.SetRejectMessage("Not a polyline.");
            opts.AddAllowedClass(typeof(Polyline), true);
            PromptEntityResult per = ed.GetEntity(opts);
            if (per.Status != PromptStatus.OK) return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                Polyline pline = (Polyline)tr.GetObject(per.ObjectId, OpenMode.ForWrite);
                pline.SetLowerLeftAboutUcsAsStartPoint();
                tr.Commit();
        private void SetLowerLeftAboutUcsAsStartPoint(Polyline pline)
            for (int i = 0; i < GetUcsLowerLeftIndex(pline); i++)
                PermuteVertices(pline);
        private int GetUcsLowerLeftIndex(Polyline pline)
            Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
            Matrix3d ucs = ed.CurrentUserCoordinateSystem;
            Extents3d bbox = pline.GeometricExtents;
            bbox.TransformBy(ucs);
            Point3d minPt = bbox.MinPoint;
            int index = 0;
            double distance = minPt.DistanceTo(pline.GetPoint3dAt(0).TransformBy(ucs));
            if (distance == 0.0)
                return 0;
            for (int i = 1; i < pline.NumberOfVertices; i++)
                double d = minPt.DistanceTo(pline.GetPoint3dAt(i).TransformBy(ucs));
                    return i;
                if (d < distance)
                    distance = d;
                    index = i;
            return index;
        private void PermuteVertices(Polyline pline)
            int lastIndex = pline.NumberOfVertices - 1;
            Point2d pt = pline.GetPoint2dAt(0);
            double bulge = pline.GetBulgeAt(0);
            double startWidth = pline.GetStartWidthAt(0);
            double endWidth = pline.GetEndWidthAt(0);
            for (int i = 0; i < lastIndex; i++)
                pline.SetPointAt(i, pline.GetPoint2dAt(i + 1));
                pline.SetBulgeAt(i, pline.GetBulgeAt(i + 1));
                pline.SetStartWidthAt(i, pline.GetStartWidthAt(i + 1));
                pline.SetEndWidthAt(i, pline.GetEndWidthAt(i + 1));
            pline.SetPointAt(lastIndex, pt);
            pline.SetBulgeAt(lastIndex, bulge);
            pline.SetStartWidthAt(lastIndex, startWidth);
            pline.SetEndWidthAt(lastIndex, endWidth);
Gilles Chanteau
Valued Contributor
hoathuongphuoc
Message 6 of 9 (336 Views)
12-29-2013 06:50 PM in reply to: _gile
Hi _gile
Its meaning
SetLowerLeftAboutUcsAsStartPoint(pline);
_gile
Message 7 of 9 (325 Views)
12-29-2013 11:21 PM in reply to: hoathuongphuoc
Yes, as SetLowerLeftAboutUcsAsStartPoint() is not defined as an extension method.
Gilles Chanteau
Valued Contributor
hoathuongphuoc
Message 8 of 9 (311 Views)
12-30-2013 03:20 AM in reply to: _gile
Its great. Thanks _gile. Thanks so much.
Valued Contributor
hoathuongphuoc
Message 9 of 9 (244 Views)
12-30-2013 11:23 PM in reply to: hoathuongphuoc
Hi _gile,
I just have met 1 mistake when i used your code.This is.
- The first when i didn't change UCS. My StartPoint is ok.
- The second when i changed UCS. My StartPoint is not correct.
Thank for your help.
You are not logged in.
Ask the Community
