.NET
New Member
Jeff_Hoffelner
Message 1 of 2 (67 Views)
Deleting a Line
67 Views, 1 Replies
12-13-2005 08:36 AM
I have been trying to delete a AcadLine object from a AutoCad 2006 drawing. I have been using the "Delete" method and then regenerating the document. This doesn't raise a error but it doesn't delete the line either. Any help you can give would be appreciated.
Thanks.
Distinguished Contributor
Mikko
Message 2 of 2 (67 Views)
Re: Deleting a Line
12-13-2005 09:02 AM in reply to: Jeff_Hoffelner
Public Sub remove_Line()
Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim tm As Transaction = db.TransactionManager.StartTransaction()
Try
Dim res As PromptSelectionResult = ed.GetSelection
If res.Status <> PromptStatus.OK Then
Exit Sub
Dim SS As Autodesk.AutoCAD.EditorInput.SelectionSet = res.Value
Dim tempIdArray() As ObjectId
tempIdArray = SS.GetObjectIds()
Dim tempId As ObjectId
For Each tempId In tempIdArray
Dim Ent As Entity = CType(tm.GetObject(tempId, OpenMode.ForWrite), Entity)
If Ent.GetType.Name.ToString() = "Line" Then
Ent.Erase()
Next
tm.Commit()
Catch
Finally
tm.Dispose()
End Try
End Sub
You are not logged in.
Announcements
Need installation help?
Ask the Community
