.NET
Delete XData
3 REPLIES 3
S.Sameith
1260 Views, 3 Replies
Delete XData
i want to delete the Xdata of an Object.
But it doesnt work. Maybe anyone can help...
Is there maybe anotherway to Delete all Xdata in a drawing ?
static public void deltexd()
Document doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
// Ask the user to select an entity
// for which to retrieve XData
PromptEntityOptions opt = new PromptEntityOptions("\nSelect entity: ");
PromptEntityResult res = ed.GetEntity(opt);
if (res.Status == PromptStatus.OK)
Transaction tr = doc.TransactionManager.StartTransaction();
using (tr)
DBObject obj = tr.GetObject(res.ObjectId, OpenMode.ForWrite);
obj.XData = new ResultBuffer();
tr.Commit();
tr.Dispose();
} Message was edited by: Niwrex
3 REPLIES 3
NathTay
in reply to: S.Sameith
This sub removes the XDATA for a specified application from the specified object.
Public Sub RemoveXData(ByVal objEntId As ObjectId, ByVal strAppName As String)
Dim objDB As Database = objEntId.Database
Dim objTrans As Transaction = objDB.TransactionManager.StartTransaction
Dim objEnt As Entity = CType(objTrans.GetObject(objEntId, DatabaseServices.OpenMode.ForWrite, False), Entity)
If objEnt.GetXDataForApplication(strAppName) Nothing Then
Dim objResBuf As ResultBuffer = New ResultBuffer
objResBuf.Add(New TypedValue(1001, strAppName))
objEnt.XData = objResBuf
objTrans.Commit()
objTrans.Dispose()
End Sub
S.Sameith
So now i do this and it works.
using (tr)
DBObject obj = tr.GetObject(res.ObjectId, OpenMode.ForWrite,false);
ResultBuffer resBuff = new ResultBuffer();
resBuff.Add(new TypedValue(1001,strAppName));
obj.XData = resBuff;
tr.Commit();
tr.Dispose();
But why i have to Add the Appname and the Type to the ResultBuffer if i want to delete it...
normaly i would say i have to create a new Resultbuffer which is empty and overwrite the XData, but this not work.
Because XData attached to an DBObject could belong to many different
applications, some of which may not be written by you. So, in general, you
only want to "remove" XData that belongs to certain application. You surely
know that you can add/remove RegAppTableRecord to/from RegAppTable of
Database to register/unregister an XData application, don't you?
"Niwrex" wrote in message news:5961051@discussion.autodesk.com...
using (tr)
tr.Commit();
tr.Dispose();
to delete it...
”Boost
