DelayLoad in .NET ?
DelayLoad in .NET ?
DelayLoad in .NET ?
I'm trying to port a custom form class that was
originally developed in Delphi to .NET.
The class provides support for modeless floating
forms in AutoCAD, as well as various other AutoCAD-
specific functionality that's commonly used in UI
based applications.
The problem I'm running into, is that in the Form
class, I cannot calll any Interop code because the
form must be instantiated in the IDE designer, which
means that Visual Studio will attempt to load any
referenced assemblies.
I see this as a massive impediment to component
based development of AutoCAD-based solutions,
because no AutoCAD interop code can be used in
any compoent that must be instantiated in the
Visual Studio IDE.
Here is an example of where the functionality is
needed. This is an override of Form.CreateParams
which sets the Form's owner window to the AutoCAD
MainFrame, and adds the WS_POPUP window style,
so AutoCAD fires WM_KEEPFOCUS messages at the
Window. Note that I can get around this specific
problem using P/Invoke (adsi_AcadMainWnd), but
this is only an _example_ for illustration purposes.
Because the form calls Interop code, I cannot derive
new Form classes from this form class, and use them
in the IDE designer:
namespace AcadUI
public class AcadModelessForm : System.Windows.Forms.Form
const UInt32 WS_OVERLAPPED = 0x00000000;
const UInt32 WS_POPUP = 0x80000000;
const UInt32 WS_CHILD = 0x40000000;
const Int32 WM_USER = 0x0400;
const Int32 WM_ACADKEEPFOCUS = WM_USER + 0x6D01;
// Handle of the AutoCAD MainFrame:
static IntPtr s_OwnerWnd = IntPtr.Zero;
// An event to query if we want to keep the focus
public delegate void OnQueryKeepFocusEvent(object sender, ref bool bKeepFocus );
public event OnQueryKeepFocusEvent OnQueryKeepFocus = null;
// This code makes the form's owner window the
// AutoCAD Mainframe, and adds the WS_POPUP style
// so AutoCAD sends us WM_KEEPFOCUS messages
protected override CreateParams CreateParams
get
if( DesignMode )
return base.CreateParams; // design-time behavior
// The following prevents this from from being used
// in the IDE designer (as a base for Inherited Forms):
if( s_OwnerWnd == IntPtr.Zero )
s_OwnerWnd = Autodesk.AutoCAD.ApplicationServices.Application.MainWindow.Handle;
Params.Parent = s_OwnerWnd;
this.TopLevel = false;
CreateParams Params = base.CreateParams;
unchecked
Params.Style |= (int) (WS_POPUP | WS_OVERLAPPED);
Params.Style &= ~ (int) WS_CHILD;
// Params.ExStyle |= (int) WS_EX_PALETTEWINDOW; // optional
return Params;
// Need to do this, because Control.Bounds is
// returning the bounds in owner/parent window
// client coordinates. Once I get rid of the WS_CHILD
// window style for the parking window this may no
// longer be necessary
public new Rectangle Bounds
get
return base.Bounds;
// TODO: Translate bounds rectangle to screen coords
protected virtual bool OnKeepFocus()
bool bKeepFocus = true;
if( this.OnQueryKeepFocus != null )
this.OnQueryKeepFocus(this, ref bKeepFocus);
else
// TODO: Implement default behavior (keep focus
// only if the mouse is in our window bounds)
return bKeepFocus;
protected override void WndProc( ref Message m )
if( ! this.DesignMode && m.Msg == WM_ACADKEEPFOCUS )
m.Result = (IntPtr) (OnKeepFocus() ? 1 : 0);
else
base.WndProc( ref m );
// A modeless Form is automatically disposed of when closed.
// We want to stop this from happening, so instead we hide
// the form which allows it to be redisplayed by calling Show(),
// or by setting the Visible property to true;
protected override void OnClosing(CancelEventArgs e)
base.OnClosing( e );
if( ! DesignMode )
e.Cancel = true;
this.Hide();
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
Yes. I understand that this is a problem in general. I think you can get
around this with careful coding. The reason VS tries to resolve the
dependency because you have the dependency in a function that is called
(hence jitted) in the designer. Try refactoring the design time and runtime
behavior into 2 separate functions like I did below. This way
GetCreateParams won't be jitted in the designer and the dependency won't
have to be resolved.
Albert
get
if( DesignMode )
return GetCreateParams(); //runtime behavior in separate function
so it won't be jitted in designer
private CreateParams GetCreateParams()
s_OwnerWnd =
unchecked
return Params;
"Tony Tanzillo" wrote in message
news:4874992@discussion.autodesk.com...
based applications.
Visual Studio IDE.
namespace AcadUI
bKeepFocus );
get
if( DesignMode )
s_OwnerWnd =
unchecked
return Params;
get
return base.Bounds;
else
return bKeepFocus;
else
if( ! DesignMode )
e.Cancel = true;
this.Hide();
Albert - Thanks for the advice.
However, it doesn't seem to work. I tried refactoring exactly as
you show, and also tried putting the code that gets the AutoCAD
window handle into a separate class and even a separate source
file, and it still happens.
The problem is not that I can't open that form in the designer.
I can do that. What I can't do, is create a form class derived from
it via the IDE (e.g., Project->Add Inherited Form), using that
form as the base class. When I try to do that, I get the exception
as soon as the IDE tries to create the derived form class.
If anyone wants to reproduce the problem, I've attached the
.cs and .resx from (Visual Studio 2003) for the form.
Just create a new ClassLibrary; reference acmgd and acdbmgd;
and add the attached form class to the project (remove any
bland class that the IDE creates).
Then build the project. Then try to create an Inherited Form
that derives from the attached one, and you'll get the exception.
"Albert Szilvasy" wrote in message news:4875015@discussion.autodesk.com...
Albert
get
if( DesignMode )
s_OwnerWnd =
unchecked
return Params;
I was puzzled enough by this problem to run Visual Studio
under Depends.exe's profiler, and it looks like the problem is
that the DesignMode property is returning false, and the code
is trying to call into the Interop to get the AutoCAD window
handle. That also explains why it doesn't fail when I create
an instance of that form class, but does when I try to derive
a new form class from it.
As it turns out, DesignMode returns true only when called from
the class that is actually instantiated in the designer, but does
not return true when called from a base class.
That is supposedly because an instance of a base class is not
what is being 'designed'.
So, I have to find another queue to see if the form is actually
running in AutoCAD or not. I can stick the call to get the Window
handle inside of a try/catch block, and deal with it that way, but
by the time the exception bubbles up, all kinds of stuff has
already happened in the IDE (e.g., the AutoCAD interop DLLs are
loaded; and AutoCAD starts doing its security thing).
Before I resort to P/Invoke, any other ideas are welcome 🙂
If you don't want to do P/Invoke you could check what the current process is
using the Process class.
Albert
news:4875206@discussion.autodesk.com...
Thanks. I'll have a look at that.
"Albert Szilvasy" wrote in message news:4875885@discussion.autodesk.com...
Albert
Thansk again. This is all that was needed:
protected bool Designing
get
Process p = Process.GetCurrentProcess();
return String.Compare(p.ProcessName, "devenv", true) == 0;
Albert
