.NET
Hallex
Message 11 of 13 (295 Views)
Re: Definition of Dynamic Blocks with .NET API
02-25-2012 08:11 AM in reply to: cean_au
I hope bobbydehero will not make a sense on me..
Try this slightly eedited code
{code}
        [CommandMethod("DynamicPropertiesTest","dyntest", CommandFlags.Modal )]
        public static void TestDynProps()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction trans = db.TransactionManager.StartTransaction())
                BlockReference bref = trans.GetObject(ed.GetEntity("\nSelect dynamic block").ObjectId, OpenMode.ForRead) as BlockReference;
                if (bref == null)
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Nothing or wrong object selected");
                    return;
                if (!bref.IsDynamicBlock)
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("selected is not dynamick block");
                    return;
                BlockTable bt = (BlockTable)(trans.GetObject(db.BlockTableId, OpenMode.ForRead));
                BlockTableRecord btrec = trans.GetObject(bref.DynamicBlockTableRecord, OpenMode.ForRead,false) as BlockTableRecord;
                string sDynBlk = btrec.Name;
                if (bt.Has(sDynBlk) == true)
                    BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[sDynBlk], OpenMode.ForRead);
                    if (btr.IsDynamicBlock)
                        try
                            DBDictionary extDictDynBT = (DBDictionary)trans.GetObject(btr.ExtensionDictionary, OpenMode.ForRead, false);
                            DBObject acadEnhancedBlk = (DBObject)trans.GetObject(extDictDynBT.GetAt("ACAD_ENHANCEDBLOCK"), OpenMode.ForRead, false);
                            EvalGraph graph = null;
                            ObjectId idGraph = acadEnhancedBlk.ObjectId;
                            if (!idGraph.IsNull)
                                graph = (EvalGraph)trans.GetObject(idGraph, OpenMode.ForRead);
                            if (graph != null)
                                int[] iNodes = graph.GetAllNodes();
                                foreach (int iNode in iNodes)
                                    DBObject node = graph.GetNode((uint)iNode, OpenMode.ForRead, trans);
                                    if (node != null)
                                        EvalExpr eExpr = node as EvalExpr;
                                        if (eExpr.GetType() == typeof(BlockLookupAction))
                                            BlockLookupAction blua = eExpr as BlockLookupAction;
                                            if (blua != null)
                                                Array pDataTable;
                                                LookupColumnDescriptorCollection descArray;
                                                blua.GetLookupTable(out pDataTable, out descArray);
                                                if (pDataTable != null)
                                                    foreach (object obj in pDataTable)
                                                        ed.WriteMessage("\n\t{0}", obj.ToString());
                                        if (eExpr.GetType() == typeof(BlockLookupParameter))
                                            BlockLookupParameter blup = eExpr as BlockLookupParameter;
                                            if (blup != null)
                                                BlockParameterPropertyDescriptorCollection props = blup.PropertyDescription;
                                                Array pDataTable;
                                                foreach (BlockParameterPropertyDescriptor prop in props)
                                                    ed.WriteMessage("\n\t{0}", prop.PropertyName);
                                                    pDataTable = prop.ValueSetValues;
                                        if (eExpr.GetType() == typeof(BlockFlipParameter))
                                            BlockFlipParameter blup = eExpr as BlockFlipParameter;
                                            if (blup != null)
                                                Array pDataTable;
                                        //---------  add other actions / parameters same way here   -------------------//
                        catch (System.Exception ex)
                            Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.ToString());
{code}
~'J'~
Valued Contributor
cean_au
Message 12 of 13 (267 Views)
02-28-2012 01:08 AM in reply to: Hallex
this still needs a dyna block first, not create one from scrath by program.
Hallex
Message 13 of 13 (261 Views)
02-28-2012 03:16 AM in reply to: cean_au
Do it yourself
I go out from there
