.NET
New Member
uomopinza
Message 1 of 13 (1,273 Views)
Definition of Dynamic Blocks with .NET API
1273 Views, 12 Replies
11-10-2008 06:56 AM
Hello, I'd like to know if it is possible, with the .NET API provided in AutoCAD 2009, to define dynamic blocks (dynamic properties and actions) completely from .NET code (VB.NET or C#).
If yes, can someone provide me a tutorial about this issue ?
Thank you.
*Tony Tanzillo
Message 2 of 13 (1,273 Views)
Re: Definition of Dynamic Blocks with .NET API
11-10-2008 08:25 AM in reply to: uomopinza
Unfortunately no, the authoring elements were not publicly
exposed.
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000
through 2009
href="http://www.acadxtabs.com">http://www.acadxtabs.com
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
from .NET code (VB.NET or C#). If yes, can someone provide me a tutorial about
this issue ? Thank you.
Valued Contributor
bert.vanpeteghem
Message 3 of 13 (1,273 Views)
01-13-2009 02:27 AM in reply to: uomopinza
Is it possible to show the dynamic properties?
I can retreive AttributeDefinitions, but no properties...
bobbydehero
Message 4 of 13 (1,273 Views)
01-13-2009 04:52 AM in reply to: uomopinza
sample code for iterating all dynamic blkrefs of MS and accessing their prop's:
using (BlockTable bt = (BlockTable)trans.GetObject(HostApplicationServices.WorkingDatabase.BlockTableId, OpenMode.ForRead, false))
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
foreach(ObjectId objId in btr)
using (DBObject dbObj = trans.GetObject(objId, OpenMode.ForRead, false))
if (dbObj != null && dbObj.GetType() == typeof(BlockReference))
try
BlockReference br = dbObj as BlockReference;
if (br != null && br.IsDynamicBlock)
DynamicBlockReferencePropertyCollection dynBlkRefProps = br.DynamicBlockReferencePropertyCollection;
foreach (DynamicBlockReferenceProperty dynProp in dynBlkRefProps)
// ... access dynprop methods
// dynProp... PropertyName, Value, GetAllowedValues()
catch (System.Exception ex)
Valued Contributor
bert.vanpeteghem
Message 5 of 13 (1,273 Views)
01-14-2009 02:31 AM in reply to: uomopinza
Hi bobbydehero,
Thanks for your answer. However, this is not what I am looking for.
What you are describing, is how to get the PropertyREFERENCES from a BlockREFERENCE.
What I need to do is find the PropertyDEFINITIONS from a BlockDEFINITION.
I can extract the AttributeDefinitions from a blockDefinitions by iterating it's entities, but I still have not found how to extract the Properties...
bobbydehero
Message 6 of 13 (1,273 Views)
01-14-2009 04:53 AM in reply to: uomopinza
Ok, I'm not sure whether this suggestion works, before I've tried myself... but you might find something if you do this:
1) try querying the BlockTableRecord (that is dynamic) extension dictionary
2) get the "ACAD_ENHANCEDBLOCK" entry and examine the resbuf's - maybe you can find something there.
Valued Contributor
bert.vanpeteghem
Message 7 of 13 (1,273 Views)
01-14-2009 05:56 AM in reply to: uomopinza
Hi, thanks, I'll try that.
For now, we'll create a BlockReference in memory and access the Properties that way...
bobbydehero
Message 8 of 13 (1,273 Views)
01-14-2009 06:10 AM in reply to: uomopinza
Yeah, that's probably wise... I ran a quick test and found out that the ACAD_ENHANCEDBLOCK dictionary entry is an EvalGraph object that is not exposed in the .Net framework (Autodesk.AutoCAD.DatabaseServices.EvalGraph).
I then tried C++ and the corresponding AcDbEvalGraph class is accessible for 3rd party dev's, but the implementation of the node classes are still not public - meaning you can only access them as AcDbObjects, here's a printout of the class descriptor names (for my sample dynamic block table record):
AcDbBlockStretchAction
AcDbBlockMoveAction
AcDbBlockVisibilityParameter
AcDbBlockVisibilityGrip
AcDbBlockGripExpr
AcDbBlockGripExpr
AcDbBlockLookupParameter
AcDbBlockLookupAction
AcDbBlockLinearParameter
AcDbBlockLinearGrip
bobbydehero
Message 9 of 13 (1,273 Views)
03-24-2009 11:04 AM in reply to: uomopinza
bertvan -
It's actually possible to read the dynamic properties from a BlockTableRecord if you for some reason still want to...
Here's some sample code, and you'll need to reference the unsupported acmgdinternal module for it (generally not recommended):
Database db = HostApplicationServices.WorkingDatabase;
using (Transaction trans = db.TransactionManager.StartTransaction())
BlockTable bt = (BlockTable)(trans.GetObject(db.BlockTableId, OpenMode.ForRead));
if (bt.Has(sDynBlk) == true)
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[sDynBlk], OpenMode.ForRead);
if (btr.IsDynamicBlock)
try
DBDictionary extDictDynBT = (DBDictionary)trans.GetObject(btr.ExtensionDictionary, OpenMode.ForRead, false);
DBObject acadEnhancedBlk = (DBObject)trans.GetObject(extDictDynBT.GetAt("ACAD_ENHANCEDBLOCK"), OpenMode.ForRead, false);
EvalGraph graph = null;
ObjectId idGraph = acadEnhancedBlk.ObjectId;
if (!idGraph.IsNull)
graph = (EvalGraph)trans.GetObject(idGraph, OpenMode.ForRead);
if (graph != null)
int [] iNodes = graph.GetAllNodes();
foreach(int iNode in iNodes)
DBObject node = graph.GetNode((uint)iNode, OpenMode.ForRead, trans);
if (node != null)
EvalExpr eExpr = node as EvalExpr;
if (eExpr.GetType() == typeof(BlockLookupAction))
BlockLookupAction blua = eExpr as BlockLookupAction;
if (blua != null)
Array pDataTable;
LookupColumnDescriptorCollection descArray;
blua.GetLookupTable(out pDataTable, out descArray);
if (pDataTable != null)
if (eExpr.GetType() == typeof(BlockLookupParameter))
BlockLookupParameter blup = eExpr as BlockLookupParameter;
if (blup != null)
BlockParameterPropertyDescriptorCollection props = blup.PropertyDescription;
foreach (BlockParameterPropertyDescriptor prop in props)
Valued Contributor
cean_au
Message 10 of 13 (694 Views)
02-25-2012 02:07 AM in reply to: uomopinza
just wondering if it can be done now?
You are not logged in.
Ask the Community
