I assume, by "BS.net", you mean VS.NET.
What version of .NET frame work installed?
Although Acad 2006 ObjectARX .NET API is built on 1.1, but by default,
Acad2006 uses latest version of .NET. So, if you use VS.NET2003 and have
.NET2.0 installed, you would get what you are experiencing: Acad2006 starts
and closes immediately while debugging. I had this experience, too.
To have Acad2006 use .NET 1.1, open "
\acad.exe.config" in
Notepad and uncomment "" and save the
change.
wrote in message news:5087461@discussion.autodesk.com...
Hi everybody --
When I try to debug an app with AutoCAD AutoCAD will launch but then closes
right away. Dose anyone have an idea what would cause this?
