.NET
Debugging in Dot net is frustrating , compare to vba
2 REPLIES 2
542 Views, 2 Replies
I just started to learn vb.net. using VS 2010 , Autocad 2010. I realized everytime I need to test my dll . I have to close Autocad . Then run dll. It will automatically open autocad . If something wrong in code . I have to close autocad and then
change the code and then run it again. Am I missing something here. I am completely new. Thanks,David.
2 REPLIES 2
Yes, unfortunately that's how it is with .NET.
You can use edit and continue on 32 bit AutoCAD.
Thanks Tony,
”Boost
