.NET
Debugging With msC#2005Express for AC2006
2 REPLIES 2
175 Views, 2 Replies
Does anyone have any tips regarding enabling Debugging with msC#2005Express
for AC2006. ??
Regards
Kerry
2 REPLIES 2
Im assuming it doesn't setup the same way as 2003?
Hello David.
C#2005Express is Significantly different to C#2003 < with which I have no
problems debugging>
[quote]
A project with an Output Type of Class Library cannot be started directly.
In order to debug this project, add an executable project to this solution
which references the library project.
Set the executable project as the startup project.
[/quote]
.. which is double dutch to me ..
Regards
Kerry
wrote in message news:4917751@discussion.autodesk.com...
”Boost
