.NET
Debugging Dlls with VB 2005 Express
1 REPLY 1
304 Views, 1 Reply
Hi All,
I am using VB 2005 Express. In exploring the product, I found that this
version of VB 2005 does not allow to debug Dlls. To debug my code, I thought
I would simply write a Windows application that would start AutoCAD, in
where the Dll code would be imported. But it does not work. For example the
following code will not result in adding a new command:
Imports ...
Public Class Class1
Public Sub Foo()
End Sub
End Class
Is conditional compilation of any hep, for example:
Imports ...
Public Class Class1
#if DLL then
Public Sub Foo()
#else
Public Foo()
#end if
End Sub
End Class
Or is there a better way of easing DLLs debugging with the Express edition ?
Gilles Plante
1 REPLY 1
There is a IDE called Sharpdevelop you can download for free that allows you
to debug .net dll's for acad
"Gilles Plante" wrote in message
news:5103102@discussion.autodesk.com...
Hi All,
Imports ...
Public Class Class1
Public Sub Foo()
End Sub
End Class
Imports ...
Public Class Class1
#if DLL then
Public Sub Foo()
#else
Public Foo()
#end if
End Sub
End Class
Gilles Plante
”Boost
