• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    Accepted Solution
    Dealing with objects in LOCKED layer
    350 Views, 3 Replies
    05-01-2012 06:14 PM
    Hi
    I am trying to assign objects (only in UNLOCKED layers) with a new layer.
    So basically, the user will select all the objects in the drawing.
    After selecting (ex. press enter after window selecting), only objects in UNLOCKED layers will have a new layer.
    Following is the code I am using...
    But I keep getting eOnLockedLayer exception.
    How should I handle this issue?
       using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                    PromptSelectionOptions pSelOpts = new PromptSelectionOptions();
                    pSelOpts.MessageForAdding = "Select all objects";
                    PromptSelectionResult pSelRes = acDoc.Editor.GetSelection(pSelOpts);
                    if (pSelRes.Status == PromptStatus.OK)
                        SelectionSet acSSet = pSelRes.Value;
                        foreach (SelectedObject acSSObj in acSSet)
                            if (acSSObj != null)
        // This line I am getting eOnLockedLayer exception
                                Entity acEnt = acTrans.GetObject(acSSObj.ObjectId, OpenMode.ForWrite) as Entity;
                                if (acEnt != null)
                                    acEnt.Layer = "newLayer";
                                    acEnt.ColorIndex = 20;
                    acTrans.Commit();
    Please use plain text.
    Valued Mentor
    KerryBrown
    Re: Dealing with objects in LOCKED layer
    05-01-2012 07:52 PM in reply to: dynamicscope
    Just stop them being selected
    // Autodesk.AutoCAD.EditorInput.PromptSelectionOptions
    public bool RejectObjectsOnLockedLayers
    Regards
    class keyThumper<T> : Lazy<T>;      another  Swamper
    I do not endorse the social media app links below:smileyembarrassed:
    *Expert Elite*
    05-01-2012 10:50 PM in reply to: dynamicscope
    ...or check the full syntax for TransAction.GetObject:
    Public Overridable Function GetObject(id As Autodesk.AutoCAD.DatabaseServices.ObjectId, mode As Autodesk.AutoCAD.DatabaseServices.OpenMode, openErased As Boolean, forceOpenOnLockedLayer As Boolean) As Autodesk.AutoCAD.DatabaseServices.DBObject
         Member von Autodesk.AutoCAD.DatabaseServices.Transaction
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Distinguished Contributor
    VB_Autocad_guy
    06-12-2012 08:16 AM in reply to: alfred.neswadba
    ForceOpenOnLockedLayer Parameter,
    That sure helped me. Thanks!:smileyhappy:
