.NET
autodeskprogrammer
Message 1 of 8 (303 Views)
Database
303 Views, 7 Replies
12-28-2012 12:32 PM
I have question ,
Do you think that I can use Autocad Database structure instead of an external database. because now I combine .DWG file and .MDB file and made .ATNX file because I should save my data in a table structure.
But now I am thinking that can I save my MDB file in Auto Cad's internal data structure?
THANX
Valued Mentor
DiningPhilosopher
Message 2 of 8 (289 Views)
Re: Database
12-28-2012 06:13 PM in reply to: autodeskprogrammer
Not entirely sure this is what you're trying to do, but if you are storing .DWG files in some data structure or blob, there is no way to read that data directly into a Database. The Database class doesn't provide a way to read a DWG file from a stream or any other source aside from disk files, so the data must be written to a file first, and then read using ReadDwgFile().
autodeskprogrammer
Message 3 of 8 (266 Views)
Re: Database
12-29-2012 02:00 PM in reply to: DiningPhilosopher
why should I save data in to a file ? now we read data directly from DWG file for example BLOCK or other Objects that we save them in internal data structure of Autocad? I want to use this internal data struture !!!
Valued Mentor
DiningPhilosopher
Message 4 of 8 (240 Views)
Re: Database
12-30-2012 12:00 PM in reply to: autodeskprogrammer
Sorry, your description doesn't really tell much about exactly what it is you're trying to achieve. If you want to offer a more detailed explaination, feel free to do so.
autodeskprogrammer
Message 5 of 8 (229 Views)
Re: Database
12-30-2012 02:59 PM in reply to: DiningPhilosopher
OK, let me to explain
In fact I save some data in Autocad internal data structure or internal database (Extension Dictionary) and I save a lot of data in MDB file and then I make a combination of dwg and mdb files and finally a combination and make a ATNX file.
it's a part of my code to show where I save my data now
 DBObject dbObject = tr.GetObject(SelectedObjectId, OpenMode.ForRead);
                    if (dbObject.ExtensionDictionary == ObjectId.Null)
                        dbObject.UpgradeOpen();
                        dbObject.CreateExtensionDictionary();
                    DBDictionary ExtensionDictionary = (DBDictionary)tr.GetObject(dbObject.ExtensionDictionary, OpenMode.ForWrite);
                    Xrecord xrec = new Xrecord();
                    xrec.Data = new ResultBuffer(
                        new TypedValue((int)DxfCode.Text, ParentCode),
                        new TypedValue((int)DxfCode.Text, NodeCode),
                        new TypedValue((int)DxfCode.Int32, NodeType),
                        new TypedValue((int)DxfCode.Int32, ProductCode),
                        new TypedValue((int)DxfCode.Real, Angle));
                    ExtensionDictionary.SetAt("AT_INFO", xrec);
now I want to know if is it possible to save my external data (the data that I save in MDB) in Autocad?
actually this DLL is very complicated and it's a worked on it about three year and now I want to improve it and I prefer not to use MDB file and instead I want to use Autocad's abilities
THANX
Hallex
Message 6 of 8 (189 Views)
Re: Database
12-31-2012 06:04 AM in reply to: autodeskprogrammer
Take a look at :
Autodesk.AutoCAD.DatabaseServices.DataTable class
this is the same as Xdata you can edit rows and columns of this table
within the drawing but could not delete it, after you add this table
in to NOD dictionary as named instance it would be persistent but editable
autodeskprogrammer
Message 7 of 8 (184 Views)
Re: Database
12-31-2012 06:28 AM in reply to: Hallex
thanx a lot , I will check it :smileyhappy:
Valued Mentor
DiningPhilosopher
Message 8 of 8 (135 Views)
Re: Database
01-03-2013 12:02 AM in reply to: autodeskprogrammer
You can store almost anything in a drawing file, but if it is not types that AutoCAD recognizes (e.g., binary data), then it becomes more difficult, but not impossible.  You can store binary data in chunks within xrecords, subject to some size limits, and there's code floating around that allows you to binary-serialize/deserialize.NET objects to/from a DWG file as well.
You are not logged in.
Ask the Community
