.NET
santoshr0114
Message 1 of 16 (1,767 Views)
Data Extraction Using .Net
1767 Views, 15 Replies
06-18-2012 04:08 AM
Hi Guys,
I need to extract data from AutoCad Drawing using C# or VB.Net.
I have a Title Block which is not inserted using attributes. It has some horizontal & vertical lines drawn  to look like a table and text added between them. See the attchment.
I need to extract data from that and display in Ms-Excel or in a datagridview.
Does anybody know how to do it ?????
It would be very helpful.
Thank You
Regards
Santosh
Distinguished Contributor
HJohn1
Message 2 of 16 (1,742 Views)
Re: Data Extraction Using .Net
06-18-2012 06:03 AM in reply to: santoshr0114
Personally I think that using attributes is more efficient than using plain text.  You can more easilly create a routine to select the block containing the attributes and also since you would know what data type is expected on each attribute validate it before you extract it.  There are many sample around on how to create selection sets, extract attributes, etc.
Hallex
Message 3 of 16 (1,728 Views)
06-18-2012 08:02 AM in reply to: santoshr0114
Upload your drawing with this block (< A2010),
maybe I can help
~'J'~
Valued Mentor
AubelecBE
Message 4 of 16 (1,699 Views)
06-19-2012 03:39 AM in reply to: Hallex
hi you can't extract plain text from a block. You have to use attribut.
Autocad have a subroutine for extract attribut. No need à code vb.net for doing this.
Hallex
Message 5 of 16 (1,707 Views)
06-19-2012 03:43 AM in reply to: AubelecBE
Sorry, but I can to do it easy,the same way as for constant attributes
using BlockTableRecord's ObjectIds of this BlockReference
~'J'~
santoshr0114
Message 6 of 16 (1,687 Views)
06-19-2012 11:07 PM in reply to: santoshr0114
Sorry for the delay in uploading the drawing file(.dwg).
First Task:
I need to extract all the text from the drawing using C# or VB.Net and display it in notepad or excel file.
Second Task:
I have to fetch only the text data from the left bottom corner(BOM) and the right bottom corner(Title Block) in the same format as it is displayed i autocad drawing and send it to excel.
Please let me know how to do it...
Regards
Santosh
Hallex
Message 7 of 16 (1,681 Views)
06-20-2012 01:29 AM in reply to: santoshr0114
In other words you want to retrive:
"AP-0298" and "Sample"
Or I'm wrong?
Just the text only or you need to get mtext as well?
~'J'~
santoshr0114
Message 8 of 16 (1,675 Views)
06-20-2012 04:04 AM in reply to: santoshr0114
Hallex,
Yes...
Regards
Santosh
Hallex
Message 9 of 16 (1,669 Views)
06-20-2012 06:22 AM in reply to: santoshr0114
Something wrong with your drawing, there are too many invisible texts,
see complete code:
using System;
using System.IO;
using System.Text;
using System.Collections;
using System.Collections.Generic;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Interop.Common;
using Autodesk.AutoCAD.Interop;
using acApp = Autodesk.AutoCAD.ApplicationServices.Application;
using Microsoft.Office.Interop.Excel;
using Excel = Microsoft.Office.Interop.Excel;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(AutoCAD_CSharp_plug_in1.ExcelReport))]
namespace AutoCAD_CSharp_plug_in1
    class ExcelReport
        [CommandMethod("xlrep")]
        public static void TextSelectToExcel()
            string title = "";
            string jobno = "";
            List<string> alltexts = new List<string>();
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            string xlFileName = (string)Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("dwgprefix");
            string dwgname = (string)Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("dwgname");
            dwgname = dwgname.Substring(0, dwgname.Length - 4) + ".xlsx";
            xlFileName = Path.Combine(xlFileName, dwgname);
            Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("osmode", 0);
            try
            using (Transaction tr = db.TransactionManager.StartTransaction())
                PromptPointOptions ppo = new PromptPointOptions("\nSelect a first corner of table: ");
                PromptPointResult ppr = ed.GetPoint(ppo);
                if (ppr.Status != PromptStatus.OK) return;
                PromptCornerOptions pco = new PromptCornerOptions("\nOther corner: ", ppr.Value);
                PromptPointResult pcr = ed.GetCorner(pco);
                if (pcr.Status != PromptStatus.OK) return;
                Point3d p1 = ppr.Value;
                Point3d p2 = pcr.Value;
                if (p1.X == p2.X || p1.Y == p2.Y)
                    ed.WriteMessage("\nInvalid coordinate specification");
                    return;
                TypedValue[] tvs = new TypedValue[]
            {new TypedValue(0, "text")
                SelectionFilter filter = new SelectionFilter(tvs);
                PromptSelectionResult result = ed.SelectCrossingWindow(p1, p2, filter);
                if (result.Status != PromptStatus.OK) return;
                Dictionary<Point3d, string> txtlist = new Dictionary<Point3d, string>();
                foreach (SelectedObject selobj in result.Value)
                    DBObject obj = tr.GetObject(selobj.ObjectId, OpenMode.ForRead) as DBObject;
                    DBText txt = obj as DBText;
                    if (txt != null)
                        string strtext = txt.TextString;
                        Point3d pp = txt.Position;
                        if (!txtlist.ContainsKey(pp))
                            txtlist.Add(pp, strtext);
                List<Point3d> ptlist = new List<Point3d>(txtlist.Keys);
                ptlist.Sort(delegate(Point3d pa, Point3d pb)
                { return (pa.Y.CompareTo(pb.Y)); });
                ptlist.Reverse();
                title = txtlist[ptlist[6]];
                jobno = txtlist[ptlist[5]];
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(string.Format
                ("Title: {0}\nJob No.: {1}", title, jobno));
                PromptSelectionResult result2 = ed.SelectAll(filter);
                if (result2.Status != PromptStatus.OK) return;
                foreach (SelectedObject selobj2 in result2.Value)
                    DBObject obj = tr.GetObject(selobj2.ObjectId, OpenMode.ForRead) as DBObject;
                    DBText txt2 = obj as DBText;
                    if (txt2 != null)
                        string strtext = txt2.TextString;
                       if (strtext!=string.Empty)
                        alltexts.Add(strtext);
            Excel.Application xlApp;
            Excel.Workbooks xlBooks;
            Excel.Workbook xlBook;
            Excel.Sheets xlSheets;
            Excel.Worksheet xlSheet;
            Excel.Range xlRange;
                xlApp = new Excel.Application();
                xlApp.Visible = false;
                xlApp.SheetsInNewWorkbook = 1;
                xlApp.Workbooks.Add(Type.Missing);
                xlBooks = (Excel.Workbooks)xlApp.Workbooks;
                xlBook = (Excel.Workbook)xlBooks[1];
                xlBook.Saved = true;
                xlApp.DisplayAlerts = false;
                xlSheets = (Excel.Sheets)xlBook.Worksheets;
                xlSheet = (Excel.Worksheet)xlSheets.get_Item(1);
                xlRange = (Excel.Range)xlSheet.Range["A1"];
                xlRange.ColumnWidth = 20;
                xlRange.NumberFormat = "@";
                int row = 1;
                xlRange.Cells[row, 1] = title;
                row = 1;
                xlRange = (Excel.Range)xlSheet.Range["B1"];
                xlRange.Cells[row, 1] = jobno;
                xlRange = (Excel.Range)xlSheet.Range["A2"];
                int r = 1;
                foreach (string s in alltexts)
                    xlRange.Cells[r, 1] = s;
                    r += 1;
                //Save workbook
                xlBook.SaveAs(xlFileName, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing,
                    Microsoft.Office.Interop.Excel.XlSaveAsAccessMode.xlNoChange, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing);
                xlApp.Workbooks.Close();
                xlApp.Quit();
                //or
                // xlApp.Windows[1].Close(false, Type.Missing, Type.Missing);
            catch (System.Exception ex)
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(
                    "\n{0}", ex.Message);
            finally
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Remove blank rows from Excel file manually");
~'J'~
santoshr0114
Message 10 of 16 (1,660 Views)
06-20-2012 08:04 AM in reply to: santoshr0114
Hallex,
Thank You.
I will try using this, but i think it asks for user to select some objects.
Let me try this now...
Regards
Santosh
You are not logged in.
Ask the Community
