.NET
*Dale Levesque
Message 1 of 2 (72 Views)
Data Breakpoint
72 Views, 1 Replies
12-14-2005 01:58 PM
Is it possible to gewt Visual Basic .Net to break when the value of a
specific variable changes? I'm using Visual Studio 2005 and it looks like
only native C/C++ allow this.
Dale
Distinguished Contributor
fantum
Message 2 of 2 (72 Views)
Re: Data Breakpoint
12-15-2005 04:22 AM in reply to: *Dale Levesque
Not directly as of at least .NET 2003. I don't know about 2005. However, you might switch to a property instead of a variable during testing so that you can set a break point in the property set procedure. Something like this:
[code]
#Const USE_PROPERTY = 1
#If USE_PROPERTY = 1 Then
Private _intX As Int32
Private Property intX() As Int32
Get
Return _intX
End Get
Set(ByVal Value As Int32)
_intX = Value 'break here
End Set
End Property
#End If
Private Sub SomeProc(ByVal arg As Whatever)
#If USE_PROPERTY = 0 Then
Dim intX As Int32 = 0
#End If
For Index As Int32 = 0 To 19
If Index Mod 3 = 0 Then
intX += 2
End If
Next
End Sub
[/code]
