.NET
Dangerous Dll - Message & Polyline thickness parameter
5 REPLIES 5
NikWach
467 Views, 5 Replies
Hi everyone,
Ich have got the following problems.
While loading the dll extension into AutoCAD (command netload), Autocad shows me a message, that the loading of those dll from that folder can be dangerous. How can I change in my source code, that a dll will authomatically recognized as non-dangerous?
Another case is, that I got a lot of thickness properties in my text-source, I want to attach them to the newly created polylines, with something like
acPoly.Thickness = Polylinie_Collection(i).BREITE
but after I open the created drawing, the polylines still have got the same thickness. Before this command I attach a colour property to the polylines and it does work. With the thickness is a large problem. I tried to set a thickness parameter to a large property, but it still didn't show it correctly.
5 REPLIES 5
Matti72
in reply to: NikWach
You get the dangerous Dll Message, if you load a dll from a place, which is not "safe"
You can configure those places
konfig
(I believe you have a german AutoCAD so it is;)
Tab: Dateien
There: Vertrauenswürdige Speicherorte
Add there the Directory, where your .dll is located and the message will go away 🙂
Matti72
Oh... there is a second question 🙂
Try to set the ConstantWidth property instead of the Thickness property. That should do, what you want.
NikWach
in reply to: Matti72
It worked, I just should have set the LWDisplay to 1, than I could see itSmiley Tongue
NikWach
Thanks for the tip, but I need to set the trusted path folder with the code - while running the application, the source folder of this application should be trusted. Is it possible with the use of .net?
Matti72
The problem is, that in order to do something with your code, the code must be loaded. So if the trusted paht is not changed you get the dangerous .dll message before you can do anything with your code.
But maybe this could help you (regarding if you install your product or do something before autocad is started...)
The trusted paht is saved in the registry:
HKEY_CURRENT_USER\Software\Autodesk\AuitoCAD\R.19.1\ACAD-D001:407\Profiles\<<Unbenanntes Profil>>\Variables -> TRUSTEDPATHS
This is the place you can adjust during insatallation to add your folder to the trustedpaths.
”Boost
