.NET
amitk_189
Message 1 of 8 (435 Views)
DWG to Image
435 Views, 7 Replies
03-01-2013 01:02 AM
Hello Everybody,
I have a basic question, i am trying to convert an autocad file to image, preferably an bmp, ti, png....etc.
Any body know how to achieve this objective since most of project parts are completed, am stuck up with this issue.
rgds
amit
Moderator
Alexander.Rivilis
Message 2 of 8 (415 Views)
Re: DWG to Image
03-01-2013 02:24 AM in reply to: amitk_189
There are two methods:
1. Plot dwg to image format with AutoCAD Plot API.
2. Using ActiveX AutoCAD Model method Export
Both of them was using more than once in this board. Let use search.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
amitk_189
Message 3 of 8 (401 Views)
Re: DWG to Image
03-01-2013 07:16 AM in reply to: amitk_189
Hello Alexander.Rivilis,
Thanks for reply, i will work on them, but i am supposed to use COM objects not inside AutoCAD. Any ideas??
Rgds
Amit
Moderator
Alexander.Rivilis
Message 4 of 8 (391 Views)
Re: DWG to Image
03-01-2013 12:31 PM in reply to: amitk_189
Do I understand correctly that you're going to work with AutoCAD from an external exe-file through ActiveX interface? If so you can use AcadDocument.Export as well as AcadDocument.Plot.PlotToXXX methods.
amitk_189
Message 5 of 8 (365 Views)
Re: DWG to Image
03-02-2013 09:06 PM in reply to: amitk_189
Thanks for Reply, yes Alexander you are right i am trying to do the same thing. Now i will work on the suggestions given by you. I will get back after some time with results
Regards
Amit
amitk_189
Message 6 of 8 (353 Views)
Re: DWG to Image
03-03-2013 06:45 AM in reply to: amitk_189
Hello Alexander,
I tried what you told to me. This is my code below
AcadApplication acadapp = new AcadApplication();
acadapp.Visible = false;
acadapp.Documents.Open(@"D:\Project\Cad Drawings\SHOP\PH#01\05-206.dwg");
AcadDocument acadDoc = acadapp.ActiveDocument;
AcadSelectionSet sset = default(AcadSelectionSet);
sset = acadDoc.PickfirstSelectionSet;
acadDoc.Export(@"e:\exportFile", "pdf", sset);
But every time i get Invalid Argument error at the export step. Any ideas
Best Regards
Amit
norman.yuan
Message 7 of 8 (347 Views)
Re: DWG to Image
03-03-2013 07:18 AM in reply to: amitk_189
Have you ever tried "Export" command in AutoCAD? If you had, you'd have known, PDF cannot be created with "EXPORT" command.
Also, the AcadDocument.Export() method does not export all the types of file the "Export" command does. If you have installed VBA, you can find this in VBA Help about what file type the Export() method can export:
<quote>
Extension
String; input-only This string should contain three characters specifying the type of file to export the drawing into. Case is not important. Use one of the following extensions: .wmf, .sat, .eps, .dsf, or .bmp.
</quote>
So, if you need to get PDF, you need to do plotting (to plot to DWG To PDF.pc3 or other PDF plotting device) instead of exporting.
amitk_189
Message 8 of 8 (335 Views)
Re: DWG to Image
03-03-2013 08:34 PM in reply to: amitk_189
You are not logged in.
Ask the Community
