.NET
Distinguished Contributor
Message 1 of 4 (1,224 Views)
DWG True View control 64-bit
1224 Views, 3 Replies
03-30-2010 07:14 AM
Hi All,
I have a VS2005 project (VB.Net) which I am migrating from a 32-bit development environment (XP) to Vista 64.
On the XP computer, I have used the DWG true View 2009 control for DWG display as per Kean's blog:
http://through-the-interface.typepad.com/through_the_interface/2007/10/au-handouts-t-1.html
>>It’s also straightforward to embed DWG TrueView in your .NET application: from your Visual Studio Toolbox, right-click and select “Choose Items…”, selecting the “COM Components” tab and then the “DWGVIEWRCtrl” item from the list of controls:<<
On the XP machine this has been simple and trouble free.
On Vista 64 I have been unable to add the control:
1. DWGVIEWRCtrl is not listed in the COM Components tab or .Net Components tab.
2. Using Browse to select the DWG True View 2009 control results in message: "Self-registration for C:\Program Files\DWG TrueView 2009\AcCtrl.dll failed"
DWG True View 2009 (x64) is installed and working ok. I don't know whether the issue is 64-bit True View, or 64-bit OS, or ????
Hopefully someone can help
Dale
New Member
gercodejager
Message 2 of 4 (823 Views)
Re: DWG True View control 64-bit
11-16-2011 06:52 AM in reply to: Dale.Bartlett
I'm having the same issue, DWG trueview 2009 & vs 2010. Have you found a solution?
Active Member
Maciej_R
Message 3 of 4 (712 Views)
03-15-2012 12:33 PM in reply to: Dale.Bartlett
Having the same problem, is it posible to embed autocad in Windows form using VS2008 on windows 7 x64? If Yes, how can I do it if most of COM component are not available?
Message 4 of 4 (605 Views)
05-30-2012 04:06 AM in reply to: Maciej_R
Sorry I haven't a solution. I am just upgrading to 2013 and have been away from the RealDWG development. If you find anything, please post. Regards, Dale
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
