.NET
Valued Contributor
bjhuffine
Message 1 of 4 (228 Views)
DIESEL Menu Command for .Net Command Loading
228 Views, 3 Replies
04-23-2012 12:39 PM
I'm trying to figure out how to create a DIESEL menu command that will check whether or not a .Net command exists.  If so, then run the command, if not run the netload command and then run it.  I'm trying to not netload it every single time the user runs the menu item.  Once loaded, I want to leave it loaded.  In fact, this particular .Net application automatically sets the registry up for demand loading.  So it only needs to run the netload the user's first time running.
Does anyone know how to do this?  Any help much appreciated....
Valued Contributor
bjhuffine
Message 2 of 4 (200 Views)
Re: DIESEL Menu Command for .Net Command Loading
04-25-2012 01:56 PM in reply to: bjhuffine
Is anyone interested in helping with this?  I didn't see any forums (unless I've overlooked them somewhere) for this... any help would be appreciated.
Moderator
Alexander.Rivilis
Message 3 of 4 (186 Views)
04-25-2012 10:36 PM in reply to: bjhuffine
DIESEL can not help you. Lisp function (getcname "CommandName") can help you. It it return nil - dll-file which define command "CommandName" is not loaded.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
bjhuffine
Message 4 of 4 (176 Views)
04-26-2012 06:01 AM in reply to: Alexander.Rivilis
Great little command for this!  Worked like a charm.  Thank you! :smileyhappy:
You are not logged in.
Ask the Community
