.NET
DGNImport
6 REPLIES 6
1256 Views, 6 Replies
DGNImport
Hello All
Does anyone know if the functionallity used in the Command DGNImport is customisable via the API?
I've had a look but I can't seem to find it, but I know there are people out there with much more familiarity with it than me.
Jason.
6 REPLIES 6
Irvin
Hi there,
I think your problem will besolved with net next block of code.
[CommandMethod("DgnAttach")]
        static public void DgnAttach()
            Database db = Application.DocumentManager.MdiActiveDocument.Database;
            using (Transaction trans = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction())
                DBDictionary nod = (DBDictionary)trans.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForWrite);
                string defDictKey = UnderlayDefinition.GetDictionaryKey(typeof(DgnDefinition));
                if (!nod.Contains(defDictKey))
                    using (DBDictionary dict = new DBDictionary())
                        nod.SetAt(defDictKey, dict);
                        trans.AddNewlyCreatedDBObject(dict, true);
                ObjectId idDgnDef;
                DBDictionary dgnDict = (DBDictionary)trans.GetObject(nod.GetAt(defDictKey), OpenMode.ForWrite);
                using (DgnDefinition dgnDef = new DgnDefinition())
                    dgnDef.SourceFileName = @"c:\Temp\yourdgnfile.dgn";
                    idDgnDef = dgnDict.SetAt("YourDgnFile", dgnDef);
                    trans.AddNewlyCreatedDBObject(dgnDef, true);
                BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
                BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                using (DgnReference dgn = new DgnReference())
                    dgn.DefinitionId = idDgnDef;
                    btr.AppendEntity(dgn);
                    trans.AddNewlyCreatedDBObject(dgn, true);
                trans.Commit();
If you want to attach a dwf file the above code can be used. You just need to change the DgnDefinition to DwfDefinition ect.
I hope this helps.
Kind regards,
Irvin
in reply to: Irvin
Irvin
Thank you for your reply.
However what I really need to do is to replicate some of the functionallity of the DGNIMPORT command not the DGNUNDERLAY (for which your code works perfectly for).
That is I need to translate the entities from the DGN file into native AutoCAD entities.
But once again thank you for your time.
Jason
sandeepkavade
Hi Jason,
I know I am replying to old thread. But have you got any success about translating the DGN entities to DWG?
I am working on the same thing, so your inputs are greatly appreciated.
Sandeep
Tags (2)
in reply to: sandeepkavade
Hi Sandeep
Unfortunately, no I did not have any success in this area.
Bentley are able to read in AutoCAD dwg format very well because of Autodesk's RealDWG. However I don't think they have anything similar to offer and AutoCAD's implementation of this doesn't seem to be public.
Sorry.
Jason
michael_vanhoose
this will work.
For
Each file As System.IO.FileInfo Infiles
TryDim sfilename AsString= file.FullName
Dim sfilenamedwg AsString = mypath & System.IO.Path.GetFileNameWithoutExtension(sfilename) & ".dwg"If System.IO.File.Exists(sfilenamedwg) = TrueThenSystem.IO.File.Delete(sfilenamedwg)
Application.DocumentManager.MdiActiveDocument.SendStringToExecute(
"-dgnimport " & sfilename & vbCr & vbCr & vbCr & vbCr, False, False, True)
"saveas" & vbCr & vbCr & sfilenamedwg & vbCr, False, False, True)
Catch ex AsException
MsgBox(ex.ToString)
EndTryNext
in reply to: michael_vanhoose
Yes michael.vanhoose code really works fine
Thanks man
”Boost
