DBObject vs. Entity
DBObject vs. Entity
DBObject vs. Entity
I'm really newb in autocad.net. I didn't understand clearly about these type.
in code from Mr. Kean Walmsley:
Transactiontr =  doc.TransactionManager.StartTransaction();
using (tr)
            DBObject obj =  tr.GetObject(id, OpenMode.ForWrite);
             tr.Commit();
But I use type Entity also can get the same result. So what is different between them. And how to use them in a good way.
Hallex
If these both are graphical objects
 so there is no difference between them,
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
To quote the ObjectARX docs: "The DBObject class is the base class for all objects that reside in an Database object." The Entity class directly inherits from DBObject. The Transaction.GetObject() method returns a DBObject type and you then cast it to other types. So if your ObjectId references an Entity, you can cast the DBObject to type Entity and then access the Entity members. I recommend you check out the ObjectARX arxmgd.chm file or use Reflector to get a better feel for the AutoCAD .NET inheritance chains.
Hallex
Thanks, I forgot about ObjectARX docs
~'J'~
