.NET
glanard
Message 1 of 4 (394 Views)
DBMOD = 32 ?
394 Views, 3 Replies
12-19-2012 11:36 PM
Can anyone give me an example how to get the system variable DBMOD = 32 or (DBMOD AND 32)=32?
Actually, I consider the drawing need really to be saved only if DBMOD is equal to 1,4 or 5. Is that right?
Moderator
Alexander.Rivilis
Message 2 of 4 (386 Views)
Re: DBMOD = 32 ?
12-20-2012 02:19 AM in reply to: glanard
In order to set DBMOD variable you can P/Invoke acdbSetDbmod function:
long __cdecl acdbSetDbmod(class AcDbDatabase *, long newDBMod);
 Example:
using System;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
[assembly: CommandClass(typeof(Rivilis.SetDbMod))]
namespace Rivilis
    public class SetDbMod
        [System.Security.SuppressUnmanagedCodeSecurity]
        [DllImport("acdb16.dll", CallingConvention = CallingConvention.Cdecl,
           EntryPoint = "?acdbSetDbmod@@YAJPAVAcDbDatabase@@J@Z")]
        private static extern Int32 acdbSetDbmod16(IntPtr db, Int32 newDbMod);
        [DllImport("acdb17.dll", CallingConvention = CallingConvention.Cdecl,
        private static extern Int32 acdbSetDbmod17(IntPtr db, Int32 newDbMod);
        [DllImport("acdb18.dll", CallingConvention = CallingConvention.Cdecl,
        private static extern Int32 acdbSetDbmod18(IntPtr db, Int32 newDbMod);
        [DllImport("acdb19.dll", CallingConvention = CallingConvention.Cdecl,
        private static extern Int32 acdbSetDbmod19(IntPtr db, Int32 newDbMod);
        public static Int32 acdbSetDbmod(ref Database db, Int32 newDbMod)
            switch (Autodesk.AutoCAD.ApplicationServices.Application.Version.Major)
                case 16: return acdbSetDbmod16(db.UnmanagedObject, newDbMod);
                case 17: return acdbSetDbmod17(db.UnmanagedObject, newDbMod);
                case 18: return acdbSetDbmod18(db.UnmanagedObject, newDbMod);
                case 19: return acdbSetDbmod19(db.UnmanagedObject, newDbMod);
                default: return (Int32)ErrorStatus.NotImplementedYet;
        // Clear DbMod for Active document
        // Очистка DBMOD для активного документа
        [CommandMethod("ClearCurDbMod")]
        static public void ClearCurDbMod()
            Database db = Application.DocumentManager.MdiActiveDocument.Database;
            acdbSetDbmod(ref db, 0);
        // Clear DbMod for All opened documents
        // Очистка DBMOD для всех документов
        [CommandMethod("ClearAllDbMod")]
        static public void ClearAllDbMod()
            foreach (Document doc in Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager)
                Database db = doc.Database;
 This code is only for x86 AutoCAD. x64 is different with  EntryPoint string:
EntryPoint = "?acdbSetDbmod@@YAJPEAVAcDbDatabase@@J@Z"
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
glanard
Message 3 of 4 (375 Views)
Re: DBMOD = 32 ?
12-20-2012 05:22 AM in reply to: Alexander.Rivilis
Hi Alexander,
Probably my question was not very clear :smileyembarrassed: (probably due to my poor english).
I do not want to set the DBMOD variable.
Futher more, I really don't see the interset to set this variable :smileysurprised:
What I wanted to know is, in the reality as a simple user, in which case this variable can be found equal to 32.
In the documentation, they talk about "field"?!
I tried some tests modifying text's field, but this does not set the DBMOD to 32...
Moderator
Alexander.Rivilis
Message 4 of 4 (354 Views)
Re: DBMOD = 32 ?
12-20-2012 10:08 AM in reply to: glanard
I do not know how a normal user can get value DBMOD = 32 without using the application.
Also, I should clarify that the function acdbSetDbmod is undocumented and unsupported and could change or go away in any future release including an API compatible release , I was reminded the guys from Autodesk.
