.NET
Amremad
Message 1 of 9 (295 Views)
Custom CommandMethod
295 Views, 8 Replies
04-17-2013 02:17 AM
hi
how can i let user that use my dll , change the command that he what
    <CommandMethod("CC")>
    Public Sub CopyMyContent()
        CopyContents.CopyContent()
    End Sub
ex :  how can i change cc to cmc
Valued Mentor
Message 2 of 9 (274 Views)
Re: Custom CommandMethod
04-17-2013 06:46 AM in reply to: Amremad
"how can i change cc to cmc": Use Alias editor in express tools.
Gaston Nunez
Amremad
Message 3 of 9 (272 Views)
04-17-2013 07:01 AM in reply to: Amremad
no no , there 's registry way to change by code
Valued Mentor
Message 4 of 9 (269 Views)
04-17-2013 07:10 AM in reply to: Amremad
There's no way to change it in the registry unless it is some sort of alias.
The command will be defined using the string given in the CommandMethod attribute.
You can define an alias for the command in the .PGP file, or with LISP.
Amremad
Message 5 of 9 (268 Views)
04-17-2013 07:15 AM in reply to: DiningPhilosopher
that's i mean , but i don't know how
dgorsman
Message 6 of 9 (253 Views)
04-17-2013 09:13 AM in reply to: Amremad
Best bet, use a verbose command name like "SOMESORTOFCOMMANDNAME" rather than "SS".  Far less likely to result in conflict with other commands and user managed aliases.  If a user wants to use "SS", "SSC", or whatever they can use the PGP to create the alias as they want.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
arcticad
Message 7 of 9 (248 Views)
04-17-2013 09:34 AM in reply to: dgorsman
I don't see that registry key in my version. is that something you added and want autocad to pick it up?
How was it assigned?
(defun botsbuildbots() (botsbuildbots))
Message 8 of 9 (239 Views)
04-17-2013 10:39 AM in reply to: Amremad
I agree with dgorsman.
By my side, I use my registered developper symbol as prefix for command names and let the user free to define aliases or to rename the command with LISP.
Gilles Chanteau
Valued Mentor
Message 9 of 9 (233 Views)
04-17-2013 11:07 AM in reply to: Amremad
The entry in the registry is how AutoCAD loads your app before the first time the command is used. As soon as it is loaded, the command is defined and AutoCAD invokes that command. It does not 'define' the name of the command as you may be presuming.
If you change that value in the registry you have to change the name of the command as well.
Adding an alias for a command is something that you should allow the user to do, which is quite easy. The reason why you shouldn't define aliases is because you don't know if the user may have already used the same alias you've chosen.
You are not logged in.
Ask the Community
