Creating polyline
Creating polyline
Message 1 of 8
Creating polyline
Hi I trying to create  polyline but Vb.net
show mee eror what is wrong in my code
thanks
Dim
line As
size=2> AutoCAD.Common.AcadLine
Dim stpoint(1),
endpoint(1)
As
Object
stpoint(0) = 0
stpoint(1) = 0
endpoint(0) = 1000
endpoint(1) = 1000
line = m_oAeccDoc2.ModelSpace.AddLine(stpoint,
endpoint)
Replies (7)
Message 2 of 8
You need 3D points.
Albert
thanks
Dim
line
size=2>As
Dim stpoint(1),
endpoint(1)
As
Object
stpoint(0) = 0
stpoint(1) = 0
endpoint(0) = 1000
endpoint(1) = 1000
endpoint)
Message 3 of 8
it must bee like now ? and mabe you know how to create
3dpolyline?
Dim
line As
Dim stpoint(2),
endpoint(2)
As
Object
stpoint(0) = 0
stpoint(1) = 0
stpoint(2) = 0
endpoint(0) = 1000
endpoint(1) = 1000
endpoint(2) = 1000
endpoint)
You need 3D points.
Albert
thanks
Dim
line
size=2>As
Dim stpoint(1),
endpoint(1)
As
Object
stpoint(0) = 0
stpoint(1) = 0
endpoint(0) = 1000
endpoint(1) = 1000
endpoint)
Message 4 of 8
No, I think you also need to declare your arrays as
Double:
Dim
stpoint(2), endpoint(2)
As
Double
Yes, I know how to create a
3dpolyline.
Albert
3dpolyline?
Dim
line
size=2>As
Dim stpoint(2),
endpoint(2)
As
Object
stpoint(0) = 0
stpoint(1) = 0
stpoint(2) = 0
endpoint(0) = 1000
endpoint(1) = 1000
endpoint(2) = 1000
endpoint)
You need 3D points.
Albert
Vb.net show mee eror what is wrong in my code
thanks
Dim
line
size=2>As
Dim stpoint(1),
endpoint(1)
As
Object
stpoint(0) = 0
stpoint(1) = 0
endpoint(0) = 1000
endpoint(1) = 1000
endpoint)
Message 5 of 8
Hi ,
Now I taing create 3D poline, I have the array
of  3d points, but hee dont crete mee the array, the eror is in the last
line, where is the problem,
thanks
Albert Szilvasy
Dim
asis As
size=2> AutoCAD.Common.Acad3DPolyline
Dim taskas(2)
As
color=#0000ff size=2>Double
Dim i, j
color=#0000ff size=2>As
size=2>Integer
Dim atstumas,
atstumas1, bx, bby, z1, cx, cy, z2
size=2>As
size=2>Double
oSites = m_oAeccDoc.Sites
Site = oSites.Item(ComboBox1.Text)
trasa = Site.Alignments.Item(ComboBox2.Text)
stotisp = trasa.Profiles.Item(ComboBox3.Text)
oAStations = trasa.GetStations(tipas.aeccMajor, 5, 5)
j = 0
Dim
taskai(oAStations.Count - 1)
As
size=2> Array
For i = 0
color=#0000ff size=2>To
color=#0000ff size=2>Step
1
stotis = oAStations.Item(i)
atstumas1 = stotis.Station
bx = stotis.Easting
bby = stotis.Northing
z1 = stotisp.ElevationAt(stotis.Station)
taskas(0) = bx
taskas(1) = bby
taskas(2) = z1
taskai(i) = taskas
Next
asis = m_oAeccDoc2.ModelSpace.Add3DPoly(taskai)
as Double:
Dim
As
size=2> Double
3dpolyline.
Albert
create 3dpolyline?
Dim
line
size=2>As
Dim stpoint(2),
endpoint(2)
As
Object
stpoint(0) = 0
stpoint(1) = 0
stpoint(2) = 0
endpoint(0) = 1000
endpoint(1) = 1000
endpoint(2) = 1000
endpoint)
You need 3D points.
Albert
thanks
Dim
line
size=2>As
Dim stpoint(1),
endpoint(1)
As
Object
stpoint(0) = 0
stpoint(1) = 0
endpoint(0) = 1000
endpoint(1) = 1000
endpoint)
Message 6 of 8
What you show below creates an AcadLine
object.  If you want to create a polyline, shouldn't you be calling
ThisDrawing.ModelSpace.AddPolyline(...) instead?
thanks
Dim
line
size=2>As
Dim stpoint(1),
endpoint(1)
As
Object
stpoint(0) = 0
stpoint(1) = 0
endpoint(0) = 1000
endpoint(1) = 1000
endpoint)
Message 7 of 8
Thanks for all polyline is created:)
For Rick
Francken, ThisDrawing is using in VBA, but when usinng
vb.net or Vb6 then using m_oAeccDoc2 or els variable
thanks
Dim
line
size=2>As
Dim stpoint(1),
endpoint(1)
As
Object
stpoint(0) = 0
stpoint(1) = 0
endpoint(0) = 1000
endpoint(1) = 1000
endpoint)
Message 8 of 8
Sorry to get hung up on the "ThisDrawing"
reference...I was thinking only of the "AddLine" versus "AddPolyline"
call.  I should not have referred to ThisDrawing at all.
-Rick
For Rick
variable
thanks
Dim
line
size=2>As
Dim stpoint(1),
endpoint(1)
As
Object
stpoint(0) = 0
stpoint(1) = 0
endpoint(0) = 1000
endpoint(1) = 1000
endpoint)
