.NET
Creating layer is not being created
2 REPLIES 2
TTIII
487 Views, 2 Replies
This code will sometimes create the layer and other times not do it, why?
Sub CreateLayer()
'' Get the current document and database
                Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
                Dim acCurDb As Database = acDoc.Database
                '' Start a transaction
                Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                    '' Open the Layer table for read
                    Dim acLyrTbl As LayerTable
                    acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite)
                    Dim sLayerName As String = "MyLayer"
                    If acLyrTbl.Has(sLayerName) = False Then
                        Dim acLyrTblRec As LayerTableRecord = New LayerTableRecord()
                        '' Assign the layer the ACI color 1 and a name
                        acLyrTblRec.Color = Color.FromColorIndex(ColorMethod.ByAci, 4)
                        acLyrTblRec.Name = sLayerName
                        '' Upgrade the Layer table for write
                        'acLyrTbl.UpgradeOpen()
                        '' Append the new layer to the Layer table and the transaction
                        acLyrTbl.Add(acLyrTblRec)
                        'acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
                        acTrans.Commit()
                    Else
                        acTrans.Dispose()
End Sub
2 REPLIES 2
kdub_nz
in reply to: TTIII
Ditch the dispose.
'End Using' block of code for the transaction
Have a look here:
http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-7BF88244-D866-40D1-8C21-7DD1A2C633DF
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
TTIII
in reply to: kdub_nz
That was the code I used, but I just deleted it and started over and it worked.
”Boost
